Content in the email sent to me (admin)
[LibreNMS] Auto update has failed for ...
We just attempted to update your install but failed. The information below
should help you fix this.
fatal: unable to access 'https://github.com/librenms/librenms.git/':
Encountered end of file
Please allow access to https://github.com/librenms/librenms.git/ if you want updates to work.
gave sudo to librenms user and resolved.
still gotten email that state:
fatal: unable to access ‘…github.com/librenms/librenms.git/’:
Could it be because my site does not have https ?
Please run and post the output of ./validate.php and ./daily.sh
-bash-4.2$ ./validate.php
LibreNMS | 1.36-84-gfca10c6
DB Schema | 237
PHP | 7.1.11
MySQL | 5.5.56-MariaDB
RRDTool | 1.4.8
SNMP | NET-SNMP 5.7.2
[WARN] Your install is over 24 hours out of date, last update: Thu, 22 Feb 2018 12:22:42 +0000
-bash-4.2$ ./daily.sh
Updating Composer packages OK
Updated from fca10c6 to 6dcdd89 OK
Updating SQL-Schema OK
Updating submodules OK
Cleaning up DB OK
Fetching notifications OK
Caching PeeringDB data OK
-bash-4.2$
[root@lnms1 user]# ls -l /etc/cron.d/librenms
-rw-r--r--. 1 root root 738 Jan 15 16:51 /etc/cron.d/librenms
[root@nms swteam]# cat /etc/cron.d/librenms
# Using this cron file requires an additional user on your system, please see install docs.
15 0 * * * librenms /opt/librenms/daily.sh >> /dev/null 2>&1
* * * * * librenms /opt/librenms/alerts.php >> /dev/null 2>&1
[root@lnms1 user]#
Prior to manual run daily.sh, the cron output and send this email received at time 0:17 /opt/librenms/daily.sh
That means you have a firewall or proxy blocking access to github, please fix that.
@laf, but it works when i ran it manually.
-bash-4.2$ /opt/librenms/daily.sh
error: RPC failed; result=6, HTTP code = 0
fatal: The remote end hung up unexpectedly
Cleaning up DB OK
fatal: unable to access 'https://github.com/librenms/librenms.git/': Could not resolve host: github.com; Name or service not known
Cleaning up DB OK
-bash-4.2$
Added google DNS
and push up google DNS as #1 to take effect.
Command line worked so far.
