HI,
I’m having trouble with running the daily.sh script which keep failing.
Here’s what it outputs :
linuxadmin@srvapp30:/opt/librenms$ ./daily.sh
WARNING: You should run this script as librenms
fatal: detected dubious ownership in repository at ‘/opt/librenms’
To add an exception for this directory, call:
git config --global --add safe.directory /opt/librenms
./composer.json has been updated
Running composer update socialiteproviders/microsoft
LibreNMS\ComposerHelper::preUpdate
Updating dependencies
Nothing to modify in lock file
Package swiftmailer/swiftmailer is abandoned, you should avoid using it. Use symfony/mailer instead.
Package symfony/debug is abandoned, you should avoid using it. Use symfony/error-handler instead.
67 packages you are using are looking for funding.
Use thecomposer fundcommand to find out more!
Illuminate\Foundation\ComposerScripts::postUpdate
Found 13 security vulnerability advisories affecting 5 packages.
Run composer audit for a full list of advisories.
Updating Composer packages FAIL
Verifying lock file contents can be installed on current platform.
Nothing to install, update or remove
Illuminate\Foundation\ComposerScripts::postAutoloadDump
@php artisan package:discover --ansi
Discovered Package: fruitcake/laravel-cors
Discovered Package: genealabs/laravel-caffeine
Discovered Package: laravel-notification-channels/webpush
Discovered Package: laravel/socialite
Discovered Package: laravel/tinker
Discovered Package: laravel/ui
Discovered Package: librenms/laravel-vue-i18n-generator
Discovered Package: mews/purifier
Discovered Package: nesbot/carbon
Discovered Package: php-flasher/flasher-laravel
Discovered Package: socialiteproviders/manager
Discovered Package: tightenco/ziggy
Package manifest generated successfully.
LibreNMS\ComposerHelper::postInstall
Illuminate\Foundation\ComposerScripts::postInstall
@php artisan vue-i18n:generate --multi-locales --format=umd
In Generator.php line 172:
file_put_contents(/opt/librenms/html/js/lang/it.js): failed to open stream:
Permission denied
Script @php artisan vue-i18n:generate --multi-locales --format=umd handling the post-install-cmd event returned with error code 1
Updated from unset to OK
Updating SQL-Schema OK
Updating submodules FAIL
Cleaning up DB OK
Fetching notifications OK
Caching PeeringDB data OK
Caching Mac OUI data OK
Here’s my validate.php:
linuxadmin@srvapp30:/opt/librenms$ ./validate.php
| LibreNMS | 22.8.0 |
| DB Schema | 2022_07_03_1947_add_app_data (244) |
| PHP | 7.4.20 |
| Python | 3.6.9 |
| Database | MariaDB 10.5.10-MariaDB-1:10.5.10+maria~bionic |
| RRDTool | 1.7.0 |
| SNMP | 5.7.3 |
[OK] Composer Version: 2.4.1
[OK]
[OK] MySQl and PHP time match
[WARN] PHP version 8.1 is the minimum supported version as of September, 2022. We recommend you update PHP to a supported version (8.1 suggested) to continue to receive updates. If you do not update PHP, LibreNMS will continue to function but stop receiving bug fixes and updates.
Not a git repository
To compare two paths outside a working tree:
usage: git diff [–no-index]
[FAIL] Failed to fetch version from local git: fatal: detected dubious ownership in repository at ‘/opt/librenms’
You can switch back to master with git checkout master
[FAIL] You need to run this script as ‘librenms’ or root
Thanks for the help
