Daily.sh fails
I am using prebuilt Centos VMware image and i’m always having problems with the daily.sh script.
It always says this error… Your local changes to the following files would be overwritten by merge:
I’ve been getting around this by using the following:
git reset --hard
git fetch --all
./scripts/github-remove -d
git pull
./daily.sh
Is there something i am missing or broken shouldn’t this be automatically removing the old files and getting new files on it’s own?
Stop doing git pull and git
its probably breaking all your permissions run the following
chown -R librenms:librenms /opt/librenms
then run ./validate.php
then
./daily.sh
Thank you for this, i have made the changes and run the scripts.
I will keep an eye on it for the next week or two.
Same problem:
[root@librenms ~]# cd /opt/librenms/
[root@librenms librenms]# ./daily.sh
error: unable to unlink old ‘includes/definitions/avaya-vsp.yaml’ (Permission de nied)
error: unable to unlink old ‘includes/definitions/ciena-sds.yaml’ (Permission de nied)
error: unable to create file tests/data/avaya-vsp_8404c.json (Permission denied)
error: unable to create file tests/snmpsim/avaya-vsp_8404c.snmprec (Permission d enied)
Updating Composer packages OK
Updating SQL-Schema OK
Updating submodules OK
Cleaning up DB OK
Fetching notifications OK
Caching PeeringDB data OK
[root@librenms librenms]# ./validate.php
LibreNMS 1.37-87-ge13920c
DB Schema 247
PHP 7.0.27
MySQL 5.5.56-MariaDB
RRDTool 1.4.8
SNMP NET-SNMP 5.7.2
[OK] Composer Version: 1.6.3
[FAIL] Database: incorrect column (notifications/datetime)
[FAIL] Database: incorrect column (users/created_at)
SQL Statements:
ALTER TABLE notifications CHANGE datetime datetime timestamp NOT NULL DEFAULT ‘1970-01-02 00:00:00’;
ALTER TABLE users CHANGE created_at created_at timestamp NOT NULL DEFAULT ‘1970-01-02 00:00:01’;
[FIX] Check your poll log and see: http://docs.librenms.org/Support/Performance/
Devices:
172.16.10.95
Modified Files:
doc/Extensions/Applications.md
Your permissons are still wacked out.
then validate
then daily again
still have the same problems…
[root@librenms librenms]# chown -R librenms:librenms /opt/librenms
DB Schema 247
PHP 7.0.27
RRDTool 1.4.8
SNMP NET-SNMP 5.7.2
SQL Statements:
Devices:
172.27.27.30
Modified Files:
error: Your local changes to the following files would be overwritten by merge:
Please, commit your changes or stash them before you can merge.
error: The following untracked working tree files would be overwritten by merge:
ciena-sds_8700.snmprec
Please move or remove them before you can merge.
Aborting
Cleaning up DB OK
Last two lines - you have modified files - so the update can’t work.
Lines above - your SQL database has issues - it tells you how to resolve that.
Hi ManOfLard,
Thanks for the help, but my problem is I’m not making changes to the SQL database, I am also not modifying files. I can’t figure out why this keeps happening.
I downloaded a clean version of the vmware image from the librenms site, all I’ve done is added a bunch of devices to monitor, but every few days ./daily.sh fails and i have to do these fixes all over again and I don’t understand whats causing this.
I have fixed the database error and removed the modified files.
When i run a ./daily.sh and ./validate.php everything is ok. I will not make any chances for the next few days and keep watching it…
Cleaning up DB OK
LibreNMS 1.37-99-g7ed7885
DB Schema 247
PHP 7.0.27
RRDTool 1.4.8
SNMP NET-SNMP 5.7.2
I’m having the same problem, but in my case I haven’t changed anything, and in the last few days I started receiving an email:
We just attempted to update your install but failed. The information below should help you fix this.
merge:
bootstrap/cache/.gitignore
logs/.gitignore
storage/app/.gitignore
storage/app/public/.gitignore
storage/debugbar/.gitignore
storage/logs/.gitignore
Please commit your changes or stash them before you merge.
Aborting
librenms
Yes this happened after a bad merge.
just run
Thank you Kevin!
Dear,
I have the same problem because add some test-documents with different name, after run ./scripts/github-remove -d , i can update with ./daily.sh without errors.
thankssss!!
