Noticed one of our librenms instances isn’t updating, hasn’t for quite some time. When I run daily.sh it doesn’t get very far. I’m a linux novice. This instance is running on red-hat enterprise version 7.6.
Any suggestions?
bash-4.2$ ./daily.sh
Updating SQL-Schema OK
Cleaning up DB OK
bash-4.2$
bash-4.2$
bash-4.2$ ./validate.php
| Component |
Version |
| LibreNMS |
1.39 |
| DB Schema |
249 |
| PHP |
7.0.15 |
| MySQL |
5.5.60-MariaDB |
| RRDTool |
1.4.8 |
| SNMP |
NET-SNMP 5.7.2 |
[OK] Composer Version: 1.9.0
[FAIL] fping6 could not be executed. fping6 must have CAP_NET_RAW capability (getcap) or suid. Selinux exlusions may be required.
((null): can’t create raw socket (must run as root?) : Address family not supported by protocol)
bash-4.2$
May be a silly question, have you already tried running the below there has been an announcement on the community for a while about this…
su - librenms
git pull
./daily.sh
Regards,
Gary
Thanks for pointing that out. Here’s the output. Do I need to specify something after git pull ?
bash-4.2$ git pull
remote: Enumerating objects: 6435, done.
remote: Counting objects: 100% (6435/6435), done.
remote: Compressing objects: 100% (8/8), done.
remote: Total 18724 (delta 6427), reused 6427 (delta 6427), pack-reused 12289
Receiving objects: 100% (18724/18724), 24.87 MiB | 17.97 MiB/s, done.
Resolving deltas: 100% (14100/14100), completed with 2200 local objects.
From https://github.com/librenms/librenms
[new branch] 1.43 -> origin/1.43
[new branch] 1_50 -> origin/1_50
[new branch] IssueAddSupportDoc -> origin/IssueAddSupportDoc
[new branch] PipoCanaja-patch-1 -> origin/PipoCanaja-patch-1
57a23a7…a0ba412 master -> origin/master
[new branch] php56 -> origin/php56
[new branch] volt-10518 -> origin/volt-10518
[new tag] 1.50.1 -> 1.50.1
[new tag] 1.40 -> 1.40
[new tag] 1.41 -> 1.41
[new tag] 1.42 -> 1.42
[new tag] 1.42.01 -> 1.42.01
[new tag] 1.43 -> 1.43
[new tag] 1.44 -> 1.44
[new tag] 1.45 -> 1.45
[new tag] 1.46 -> 1.46
[new tag] 1.47 -> 1.47
[new tag] 1.48 -> 1.48
[new tag] 1.48.1 -> 1.48.1
[new tag] 1.49 -> 1.49
[new tag] 1.50 -> 1.50
[new tag] 1.51 -> 1.51
[new tag] 1.52 -> 1.52
[new tag] 1.53 -> 1.53
[new tag] 1.53.1 -> 1.53.1
[new tag] 1.54 -> 1.54
You are not currently on a branch. Please specify which
branch you want to merge with. See git-pull(1) for details.
git pull
bash-4.2$
bash-4.2$
bash-4.2$
bash-4.2$
Cleaning up DB OK
bash-4.2$
Ok, paste the output of the following…
su - librenms
git log -n 1
git status
Thanks for your ongoing help. Here’s the output.
-bash-4.2$ cd /opt/librenms/
-bash-4.2$ git log -n 1
commit 386fea0321a86b197d302629a04d20d480828d6d
Author: Neil Lathwood [email protected]
Date: Sun Apr 29 21:42:40 2018 +0100
docs: Changelog for 1.39 Apr 2018 (#8636)
-bash-4.2$
-bash-4.2$ git status
HEAD detached at 1.39
Untracked files:
(use “git add …” to include in what will be committed)
scripts/rrdstep.php.bak
nothing added to commit but untracked files present (use “git add” to track)
-bash-4.2$
Any suggestions on what I could try next?
Any advice on this issue?
