Daily.sh keeps failing
Here is the output. Can’t find out where it’s going wrong:
[email protected]:~$ ./daily.sh
fatal: unable to access ‘https://github.com/librenms/librenms.git/’: gnutls_handshake() failed: Access was denied
Updating Composer packages OK
Updating SQL-Schema OK
Updating submodules OK
Cleaning up DB OK
Fetching notifications OK
Caching PeeringDB data OK
Cant reach out to GitHub - Do you have a web filter or a proxy?
TLS failed, could be old TLS support or bad system time (make sure time is correct).
