Hi all,
I hope this question has not been answered before and that this post is “yet another”. I am using LibreNMS on CentOS but for some reason my ./daily.sh gives me an error everyday. I am a novice with Linux so there will probably be some newbie questions or mistakes, sorry for that in advance.
Warning: Your install is over 24 hours out of date, last update: Mon, 26 Aug 2019 14:42:27 +0000Fix:
My Cron jobs for LibreNMS:
[root@localhost user]# cat /etc/cron.d/librenms
#Using this cron file requires an additional user on your system, please see install docs.33 */6 * * * librenms /opt/librenms/cronic /opt/librenms/discovery-wrapper.py 1
** * * * librenms /opt/librenms/alerts.php >> /dev/null 2>&1
*/5 * * * * librenms /opt/librenms/check-services.php >> /dev/null 2>&1#Daily maintenance script. DO NOT DISABLE!
#If you want to modify updates:
#Switch to monthly stable release: Choosing a release - LibreNMS Docs
#Disable updates: Updating - LibreNMS Docs
15 0 * * * librenms /opt/librenms/daily.sh >> /dev/null 2>&1
My ./validate.php tells me the following. Before you say, yeah you have to fix the local git modified files: I have a cron job running an extra script which I will post after the ./validate.php
./validate.php
Component Version LibreNMS 1.54-56-g7783776 DB Schema 2019_07_09_150217_update_users_widgets_settings (140) PHP 7.2.19 MySQL 5.5.60-MariaDB RRDTool 1.4.8 SNMP NET-SNMP 5.7.2 ==================================== [OK] Composer Version: 1.9.0
[WARN] Your install is over 24 hours out of date, last update: Mon, 26 Aug 2019 14:42:27 +0000
Modified Files:
bootstrap/cache/.gitignore
logs/.gitignore
rrd/.gitignore
storage/app/.gitignore
storage/app/public/.gitignore
storage/debugbar/.gitignore
storage/logs/.gitignore
Now, the reason there are modified files, I think at least, is because I created a ./fixrights.sh and added a cron for this so it runs every few minutes. The reason I created this is because LibreNMS was constantly losing user rights. I have checked the forum and found users with the same issue. They solved it with the script, and it worked for me too. Important notice: I did this because I thought it was the reason that the ./daily.sh script did not run every day. Not sure if I fixed it partially or not at al. In any case, the script does the following:
./fixrights.sh
sudo setfacl -R -m g::rwx /opt/librenms/rrd /opt/librenms/logs /opt/librenms/bootstrap/cache/ /opt/librenms/storage/
However, if I follow the the command to remove the modified Git files, my ./validate looks like this:
./validate.php
Files:
/opt/librenms/.git/index
/opt/librenms/logs/.gitignore
/opt/librenms/rrd/.gitignore
/opt/librenms/storage/app/public/.gitignore
/opt/librenms/storage/app/.gitignore
/opt/librenms/storage/framework/testing/.gitignore
/opt/librenms/storage/logs/.gitignore
Again, the script I have will fix the user rights because even if I enter the suggested commands to give ownership towards my Librenms user it will revert itself.
Does anyone have any idea what I am doing wrong?
If it helps, my ./daily.sh runs fine if I enter the command:
./daily.sh
Updating Composer packages OK
Updated from 7783776 to 7811227 OK
Updating SQL-Schema OK
Updating submodules OK
Cleaning up DB OK
Fetching notifications OK
Caching PeeringDB data OK
Aside from this, LibreNMS runs perfectly fine. I hope someone can help.
