First I saw that the librenms did’nt update since a while :
-bash-4.2$ ./validate.php
Component | Version |
LibreNMS | 1.48.1-25-g21192a9 |
DB Schema | 2019_01_16_195644_add_vrf_id_and_bgpLocalAs (131) |
PHP | 7.2.27 |
MySQL | 5.5.56-MariaDB |
RRDTool | 1.6.0 |
SNMP | NET-SNMP 5.7.2 |
[OK] Composer Version: 1.10.1
[FAIL] The poller (xxx) has not completed within the last 5 minutes, check the cron job.
Devices:
xxx
[WARN] Your install is over 24 hours out of date, last update: Fri, 08 Feb 2019 14:17:29 +0000
[WARN] You are on the PHP 5.6/7.0 support branch, this will prevent automatic updates.
Update to PHP 7.1.3 or newer (PHP 7.2 recommended) to continue to receive updates.
Modified Files:
includes/polling/cisco-remote-access-monitor.inc.php
mibs/adva/ADVA-FSPR7-CAP-MIB.mib
mibs/adva/ADVA-FSPR7-CFM-EXTENSION-MIB.mib
mibs/adva/ADVA-FSPR7-DEF-MIB.mib
mibs/adva/ADVA-FSPR7-MIB.mib
mibs/adva/ADVA-FSPR7-MODULE-ENCRYPTION-MIB.mib
mibs/adva/ADVA-FSPR7-PM-MIB.mib
mibs/adva/ADVA-FSPR7-TC-MIB.mib
mibs/adva/ADVA-MIB.mib
mibs/adva/fsp150cm-alarm.mib
mibs/adva/fsp150cm-amp.mib
mibs/adva/fsp150cm-bfd.mib
mibs/adva/fsp150cm-bridge.mib
mibs/adva/fsp150cm-cap.mib
mibs/adva/fsp150cm-cfm.mib
and 67 more…
I forced the update with git :
git init
git remote add origin https://github.com/librenms/librenms.git
git fetch
git reset origin/master --mixed
But I still have problem :
LibreNMS | 1.62-35-g01350a2 |
PHP | 7.2.27 |
RRDTool | 1.6.0 |
[FAIL] The poller (xxx-nocmon.xxx) has not completed within the last 5 minutes, check the cron job.
Devices:
xxxx
xxxx
xxxx
Modified Files:
.editorconfig
.env.dusk.testing
.github/FUNDING.yml
.github/ISSUE_TEMPLATE.md
.github/ISSUE_TEMPLATE/New-Device.md
.github/PULL_REQUEST_TEMPLATE.md
.gitignore
.travis.yml
AUTHORS.md
CONTRIBUTING.md
LibreNMS/Alert/AlertDB.php
LibreNMS/Alert/AlertRules.php
LibreNMS/Alert/AlertUtil.php
LibreNMS/Alert/RunAlerts.php
LibreNMS/Alert/Template.php
and 2676 more…
Thanks in advance
Best regards
David
