I am having 2 problems that I can’t figure out how to get around.
- librenms@stat:~$ ./daily.sh
fatal: unable to access ‘https://github.com/librenms/librenms.git/’: gnutls_handshake() failed: Access was denied
Updating Composer packages OK
Updating SQL-Schema OK
Updating submodules OK
Cleaning up DB OK
Fetching notifications OK
Caching PeeringDB data OK
as possible. This should include:
- The output of
./validate.php
I am unsure why this is failing.
2) I changed the ip address on the linux box and the webserver is continuing to go to the old ip.
librenms@stat:~$ ./validate.php
Component | Version |
LibreNMS | 1.67-48-g65b294c7c |
DB Schema | 2020_08_28_212054_drop_uptime_column_outages (173) |
PHP | 7.4.3 |
Python | 3.8.2 |
MySQL | 10.3.22-MariaDB-1ubuntu1 |
RRDTool | 1.7.2 |
SNMP | NET-SNMP 5.8 |
[OK] Composer Version: 1.10.13
[WARN] Your install is over 24 hours out of date, last update: Sat, 19 Sep 2020 23:24:53 +0000
OK, fixed #2 forgot to change ip in the nginx.conf file
