my librenms is behind a firewall with no internet access. I am trying to have daily.sh use the socks5 proxy when checking/updating master.
| Version | 1.36-10-g5384d1c - Tue Jan 30 2018 16:16:18 GMT-0500 |
| DB Schema | #232 |
| Web Server | nginx/1.12.2 |
| PHP | 7.0.25 |
| MySQL | 5.5.56-MariaDB |
| RRDtool | 1.6.0 |
STEPS
From the CML as root:
ssh -N -D 9999 [email protected]
From another CML as root:
cd /opt/librenms
git config --global http.proxy socks5://localhost:9999
git pull
remote: Counting objects: 719, done.
remote: Compressing objects: 100% (20/20), done.
remote: Total 719 (delta 519), reused 519 (delta 514), pack-reused 185
Receiving objects: 100% (719/719), 640.52 KiB | 0 bytes/s, done.
Resolving deltas: 100% (563/563), completed with 270 local objects.
From https://github.com/librenms/librenms
788c0bd..5384d1c master -> origin/master
* [new branch] 1.36 -> origin/1.36
* [new branch] kkrumm1-patch-1 -> origin/kkrumm1-patch-1
6ebec8a..7982114 php53 -> origin/php53
* [new tag] 1.36.01 -> 1.36.01
* [new tag] 20160828 -> 20160828
* [new tag] 201609 -> 201609
* [new tag] 201609.01 -> 201609.01
* [new tag] 1.36 -> 1.36
Updating 788c0bd..5384d1c
Fast-forward
.gitignore | 1 -
.travis.yml | 2 +-
AUTHORS.md | 1 +
LibreNMS/Alert/Transport/Pushover.php | 9 +-
LibreNMS/Authentication/SSOAuthorizer.php | 6 +-
LibreNMS/ComposerHelper.php | 7 +
LibreNMS/OS/Ptp250.php | 18 +-
LibreNMS/OS/Ptp500.php | 146 +
Looks like it needed a lot of changes
But daily.sh does not work…
./daily.sh
fatal: unable to access 'https://github.com/librenms/librenms.git/': Failed connect to github.com:443; Operation now in progress
Updating SQL-Schema OK
Updating submodules OK
Cleaning up DB OK
Fetching notifications OK
Caching PeeringDB data OK
But git pull does
git pull
Already up-to-date.
So then i appended to /opt/librenms/.git/config
[http]
proxy = socks5://localhost:9999
Then daily.sh worked:
./daily.sh
Updated from 5384d1c to 8a91768 OK
Cleaning up DB OK
Not sure is this is the best way to do this… ???
Is there an option withing config.php that i can set?
Thank you,
dave
