I think it would be great if it was possible to remove the widget title bar and put the widget tiltle inside the wiget like in Observium, this would free up alot ospace on the dashboard. And for instance the world map widget don’t need a title at all imo.
And also if it was possible to select where to place the widget toolbar with the edit and remove button, so you can place it in the bottom of the dashboard instead.
