This is the first time I haven’t been able to type the port name/number and find the port in the list. Is there a way to see all the ports from a specific IP on the list. I did try the port=6417 using the port id but I did not get that to work. Is there a way to uses something besides the 1/1/… or 1-1-… format? I tried putting “hostname”=“x.x.x.x” with no luck.
Bryan
