My dashboard graph widgets with Interface Description Parsing. Stopped working a few monts ago. Most likely after a upgrade, but i dont know what update.
When i create a graph widget with the “transit” aggreagator, the graph show “error: absolute path names not all”. Would like this function to work again asap.
Not enough info to determine the problem. can you post the exact parsing info?
absolute path not allowed usually means you have pathing wrong somewhere.
lest say the command run in “/data/1/” and you need to access to “/data/2/”
Absolut pathing would be “/data/2/” but what the command will accept is “…/2/” (= from where I am go back one, then open folder 2)
I am using the built in “transit” parsing that is build into librenms. If i go to ports->Transit. Alle of my interfaces show up just fine, and graphs are working.
