We have faced dashboard length limit. When are are trying to modify existing dashboards or create new one, we are unable to scroll down and add more than 10-12 widgets. When we create next 13th widget it doesnt more downstairs, it just overrides one of the existing widgets.
Hello, unfortunately there is a limit from the widget js, someone posted a fix but just be careful as by modifying core files you could break a future update of librenms etc… 15 Widget - Dashboard Limit?
i think it’s an overall size constraint of rows, so maybe 15 normal or small size widgets will fit, but if you have 2 large widgets that take up the max rows set by that gridster js, then thats all you can have.
