I have a issue with my librenms.
I erased all widget in my dashboard and i want recreat all but i have error message.
For exemple, when i add widgets Worlmap and i want to improve the window.
I have this message :
Have you a solution ?
Cdlt,
please validate your install and post the output.
root@uvinct648:/usr/local/share/librenms# ./validate.php
| Component |
Version |
| LibreNMS |
1.35-86-g2fb8dd790 |
| DB Schema |
228 |
| PHP |
7.0.19-1 |
| MySQL |
5.5.58-0+deb7u1-log |
| RRDTool |
1.6.0 |
| SNMP |
NET-SNMP 5.7.3 |
[FIX] Check the cron job to make sure it is running and using discovery-wrapper.py
sh: 1: 1: not found
sh: 1: 1: not found
[FAIL] fping could not be executed. fping must have CAP_NET_RAW capability (getcap) or suid. Selinux exlusions may be required.
(This account is currently not available.)
[FAIL] fping should have CAP_NET_RAW!
[FIX] setcap cap_net_raw+ep /usr/bin/fping
[FAIL] fping6 could not be executed. fping6 must have CAP_NET_RAW capability (getcap) or suid. Selinux exlusions may be required.
[FAIL] fping6 should have CAP_NET_RAW!
[FIX] setcap cap_net_raw+ep /usr/bin/fping6
[WARN] Your install is over 24 hours out of date, last update: Tue, 09 Jan 2018 22:13:47 +0000
Modified Files:
You need to fix all those Fails first.
