Since running last daily.sh I get following error after running validate.sh:
[librenms@fh-vm-noc05 ~]$ /opt/librenms/daily.sh
Updating Composer packages OK
Updating SQL-Schema OK
Updating submodules OK
Cleaning up DB OK
Fetching notifications OK
Caching PeeringDB data OK
[librenms@fh-vm-noc05 ~]$ /opt/librenms/validate.php
Component |
Version |
LibreNMS |
1.47-103-gea63321 |
DB Schema |
1000 |
PHP |
7.2.14 |
MySQL |
5.5.62 |
RRDTool |
1.4.7 |
SNMP |
NET-SNMP 5.5 |
[OK] Composer Version: 1.8.0
[FAIL] Database: missing constraint (device_group_device/device_group_device_device_group_id_foreign)
[FAIL] Database: missing constraint (device_group_device/device_group_device_device_id_foreign)
[FAIL] Database: missing constraint (wireless_sensors/wireless_sensors_device_id_foreign)
[FAIL] We have detected that your database schema may be wrong, please report the following to us on Discord (https://t.libren.ms/discord) or the community site (https://t.libren.ms/5gscd):
SQL Statements:
ALTER TABLE device_group_device
ADD CONSTRAINT device_group_device_device_group_id_foreign
FOREIGN KEY (device_group_id
) REFERENCES device_groups
(id
) ON DELETE CASCADE;
ADD CONSTRAINT device_group_device_device_id_foreign
FOREIGN KEY (device_id
) REFERENCES devices
(device_id
ALTER TABLE wireless_sensors
ADD CONSTRAINT wireless_sensors_device_id_foreign
(device_id
But running the adviced SQL statements doesnât solve the problem. it stays the same âŠ
Any idea?
Possibly should be some statements to drop the existing indexesâŠ
You could have data that violates the constraint too. You need to post the sql error.
Is the mysql installation to old? Or is there another problem?
Can I reimport the last sql schmea (1000.sql)?
190121 13:57:15 [ERROR] Missing system table mysql.proxies_priv; please run mysql_upgrade to create it
190121 13:57:15 [ERROR] Native table âperformance_schemaâ.âevents_waits_currentâ has the wrong structure
190121 13:57:15 [ERROR] Native table âperformance_schemaâ.âevents_waits_historyâ has the wrong structure
190121 13:57:15 [ERROR] Native table âperformance_schemaâ.âevents_waits_history_longâ has the wrong structure
190121 13:57:15 [ERROR] Native table âperformance_schemaâ.âsetup_consumersâ has the wrong structure
190121 13:57:15 [ERROR] Native table âperformance_schemaâ.âsetup_instrumentsâ has the wrong structure
190121 13:57:15 [ERROR] Native table âperformance_schemaâ.âsetup_timersâ has the wrong structure
190121 13:57:15 [ERROR] Native table âperformance_schemaâ.âperformance_timersâ has the wrong structure
190121 13:57:15 [ERROR] Native table âperformance_schemaâ.âthreadsâ has the wrong structure
190121 13:57:15 [ERROR] Native table âperformance_schemaâ.âevents_waits_summary_by_thread_by_event_nameâ has the wrong structure
190121 13:57:15 [ERROR] Native table âperformance_schemaâ.âevents_waits_summary_by_instanceâ has the wrong structure
190121 13:57:15 [ERROR] Native table âperformance_schemaâ.âevents_waits_summary_global_by_event_nameâ has the wrong structure
190121 13:57:15 [ERROR] Native table âperformance_schemaâ.âfile_summary_by_event_nameâ has the wrong structure
190121 13:57:15 [ERROR] Native table âperformance_schemaâ.âfile_summary_by_instanceâ has the wrong structure
190121 13:57:15 [ERROR] Native table âperformance_schemaâ.âmutex_instancesâ has the wrong structure
190121 13:57:15 [ERROR] Native table âperformance_schemaâ.ârwlock_instancesâ has the wrong structure
190121 13:57:15 [ERROR] Native table âperformance_schemaâ.âcond_instancesâ has the wrong structure
190121 13:57:15 [ERROR] Native table âperformance_schemaâ.âfile_instancesâ has the wrong structure
DB Schema changed with last daily update, but the error stays the same.
SQL statements didnât fix the problem:
[root@fh-vm-noc05 librenms]$ ./validate.php ====================================
Component |
Version |
LibreNMS |
1.47-101-gd6b1024 |
DB Schema |
2019_01_16_195644_add_vrf_id_and_bgpLocalAs (131) |
PHP |
7.2.14 |
MySQL |
5.5.62 |
RRDTool |
1.4.7 |
SNMP |
NET-SNMP 5.5 |
SQL Statements:
(id
(device_id
(device_id
You should run mysql_upgrade
Run show create table device_group_device;
for each of these tables and post the output.
I did the mysql_upgrade, seems to run fine.
This is the output of the two affected tables from the ./validate.php script:
mysql> show create table device_group_device;
| Table | Create Table |
| device_group_device | CREATE TABLE device_group_device
device_group_id
int(10) unsigned NOT NULL,
device_id
PRIMARY KEY (device_group_id
,device_id
KEY device_group_device_device_group_id_index
(device_group_id
KEY device_group_device_device_id_index
(device_id
) ENGINE=MyISAM DEFAULT CHARSET=utf8 COLLATE=utf8_unicode_ci |
1 row in set (0.00 sec)
mysql> show create table wireless_sensors;
| wireless_sensors | CREATE TABLE wireless_sensors
sensor_id
int(10) unsigned NOT NULL AUTO_INCREMENT,
sensor_deleted
tinyint(1) NOT NULL DEFAULT â0â,
sensor_class
varchar(64) COLLATE utf8_unicode_ci NOT NULL,
device_id
int(10) unsigned NOT NULL DEFAULT â0â,
sensor_index
varchar(64) COLLATE utf8_unicode_ci DEFAULT NULL,
sensor_type
varchar(255) COLLATE utf8_unicode_ci NOT NULL,
sensor_descr
varchar(255) COLLATE utf8_unicode_ci DEFAULT NULL,
sensor_divisor
int(11) NOT NULL DEFAULT â1â,
sensor_multiplier
sensor_aggregator
varchar(16) COLLATE utf8_unicode_ci NOT NULL DEFAULT âsumâ,
sensor_current
double DEFAULT NULL,
sensor_prev
sensor_limit
sensor_limit_warn
sensor_limit_low
sensor_limit_low_warn
sensor_alert
tinyint(1) NOT NULL DEFAULT â1â,
sensor_custom
enum(âNoâ,âYesâ) COLLATE utf8_unicode_ci NOT NULL DEFAULT âNoâ,
entPhysicalIndex
varchar(16) COLLATE utf8_unicode_ci DEFAULT NULL,
entPhysicalIndex_measured
lastupdate
timestamp NOT NULL DEFAULT CURRENT_TIMESTAMP,
sensor_oids
text COLLATE utf8_unicode_ci NOT NULL,
access_point_id
int(10) unsigned DEFAULT NULL,
PRIMARY KEY (sensor_id
KEY sensor_class
(sensor_class
KEY sensor_host
(device_id
KEY sensor_type
(sensor_type
Hey Murrant,
do you have any suggestion for my DB Problem?
I made fresh install on Ubunut and migrated my data. But the error stays. So Itâs definitly something which is going wrong in the DB. Is there a way to reimport SQL schema? Which ist the last one?
Or do you have any other idea? THX for helping
Possibly you have some data in your database and blocking the foreign keys.
Problem solved:
mysql was running in âmyisamâ mode. This doesnât accept constraints.
Switching / migrating to innodb mode solved the problem
We could add a check for this in validate. How can you detect what is being used?
Check for Engine=MyISAM and replace this in all affected tables with Engine=InnoDB
- dump affected DB
- sed -e âs/MyISAM/InnoDB/â < librenms_dump_origin_myisam.sql > librenms_dump_adapted_innodb.sql
- import adapted DB
more info:
â> https://dev.mysql.com/doc/refman/8.0/en/converting-tables-to-innodb.html
Example:
origin:
DROP TABLE IF EXISTS device_group_device
/*!40101 SET @saved_cs_client = @@character_set_client /;
/!40101 SET character_set_client = utf8 /;
device_group_id
device_id
,device_id
(device_group_id
(device_id
) ENGINE=MyISAM DEFAULT CHARSET=utf8 COLLATE=utf8_unicode_ci;
/!40101 SET character_set_client = @saved_cs_client */;
adapted:
device_group_id
device_id
,device_id
(device_group_id
(device_id
(id
) ON DELETE CASCADE,
(device_id
) ON DELETE CASCADE
) ENGINE=InnoDB DEFAULT CHARSET=utf8 COLLATE=utf8_unicode_ci;
