During the fresh install.php is stuck at “DB build please wait”
Can someone please help identify an issue here? How long does it take for the install.php to go to the next step?
Since CentOs 8 is EoS/EoL, need to setup this up on cento7.6
bash-4.2$ ./validate.php
Component
Version
LibreNMS
21.4.0-62-ge40e106
DB Schema
Not Connected (0)
PHP
7.3.28
Python
3.6.8
MySQL
RRDTool
1.4.8
SNMP
NET-SNMP 5.7.2
[OK] Composer Version: 2.0.13
Thanks,
MK.
Is your database running, started, installed?
Yes i think so?
bash-4.2$ systemctl status mariadb
● mariadb.service - MariaDB database server
Loaded: loaded (/usr/lib/systemd/system/mariadb.service; enabled; vendor preset: disabled)
Active: active (running) since Wed 2021-05-05 04:01:23 UTC; 2 days ago
Main PID: 20695 (mysqld_safe)
CGroup: /system.slice/mariadb.service
├─20695 /bin/sh /usr/bin/mysqld_safe --basedir=/usr
└─20886 /usr/libexec/mysqld --basedir=/usr --datadir=/var/lib/mysql --plugin-dir=/usr/lib64/mysql/plugin --log-error=/var/log/mariadb/mariadb.log --pid-file=/var/run/mariadb/mariadb.pid --socket=/var/lib/mysql/mysql.s…
bash-4.2$
Too old mysql version I’m guessing
After going through multiple articles and docs , following is the latest error i am getting;
Component
Version
LibreNMS
21.4.0-68-g99db4bf
DB Schema
2018_07_03_091314_create_alert_log_table (4)
PHP
7.3.28
Python
3.6.8
MySQL
5.5.68-MariaDB
RRDTool
1.4.8
SNMP
NET-SNMP 5.7.2
In Connection.php line 678:
SQLSTATE[42S02]: Base table or view not found: 1146 Table ‘librenms.devices’ doesn’t exist (SQL: select exists(select * from devices
) as exists
In Exception.php line 18:
In PDOConnection.php line 79:
Secondly, per all the doc majority of the things i did were over the cli/command prompt.
But isnt install.php suppose to enable it through the GUI. wondering why am i still seeing this error on the browser:
Not Found
The requested URL /install.php was not found on this server.
Hi @MK13
Your MariaDB installed version is too old for LibreNMS to succeed. You need to upgrade to something newer than 10.2 to get it right. You have plenty posts in this forum with people having this issue.
Bye
YES!!
Thanks a bunch folks.
Its Up and Operational.
Next Step enable/discover other features.
system
Closed
19 May 2021 05:09
10
