Librenms NMS down. error showing on gui page is (Whoops, looks like something went wrong. Check your librenms.log.)
here is the output of ./validate.php
In StreamHandler.php line 178:
fwrite(): Write of 3277 bytes failed with errno=28 No space left on device
Component
Version
LibreNMS
22.10.0-113-gc26cbc9a4 (2022-11-14T21:19:08+05:00)
DB Schema
Not Connected (0)
PHP
8.1.2-1ubuntu2.8
Python
3.10.6
Database
Not Connected
RRDTool
1.7.2
SNMP
5.9.1
[OK] Composer Version: 2.4.4
what is way around to fix it! as I am unable to access web gui access of the server!
I have added disk size and increase memory size in librenms proxmox vm. what files needed to be deleted so that I can retain minimum from previous data & configuration?
Some files you need to keep are:
/opt/librenms/.env
/opt/librenms/rrd
/opt/librenms/config.php
And your database.
You should have backups in case I missed anything.
ski522
19 November 2022 10:00
7
Interesting to see you ran out of disk space now a days. I’m monitoring several hundred devices and I’m using just 9 GB in my /opt/librenms directory and my database is only 200 MB.
I’d assume OP has a million logs they’re not rotating, just based off experience. But don’t know.
system
Closed
19 February 2023 23:03
9
