Fresh install on centos8 with apache.
Component | Version |
LibreNMS | 1.70.1-37-g709d1b6f5 |
DB Schema | No Schema (0) |
PHP | 7.3.20 |
Python | 3.6.8 |
MySQL | 10.3.27-MariaDB |
RRDTool | 1.7.0 |
SNMP | NET-SNMP 5.8 |
[OK] Composer Version: 2.0.8
In Connection.php line 678:
SQLSTATE[42S02]: Base table or view not found: 1146 Table ‘librenms.devices’ doesn’t exist (SQL: select exists(s
elect * from devices
) as exists
In Exception.php line 18:
In PDOConnection.php line 78:
- The output of
./validate.php
initially I had just no schema so i added the password and database name to .env. and now i have the sqlstate[ errors]
Any help would be appreciated.
