I’m using Default alert template
and there is a lot of information which is not needed !
All what I want to receive is the name of the device and of course the time when the device or the service is down and the Service description and that’s it
Can anyone help me which lines should I delete !
{{ $alert->title }}
Severity: {{ $alert->severity }}
@if ($alert->state == 0) Time elapsed: {{ $alert->elapsed }} @endif
Rule: @if ($alert->name) {{ $alert->name }} @else {{ $alert->rule }} @endif
@if ($alert->faults) Faults:
{{ $key }}: {{ $value['string'] }}
@endforeach
@endif
Alert sent to:
@foreach ($alert->contacts as $key => $value)
{{ $value }} <{{ $key }}>
@endforeach
Best Regards
