Where I can find what default OIDs Librenms uses to query devices.
Hello @Sebastian_Wielgosz
This depends on the device you have, the modules you enable/disable, etc etc. So what is your issue ?
Bye
Probably the network device (Dasan) has a memory leak when reading snmp through Librenms. I need to send OIDs to Dasan developers.
Run discovery and poller with debug and you can see what snmp commands it runs
Even better, do that and do a wireshark/tcpdump capture of the discovery and polling, and give them the file. That way, they’ll have all details they need.
Thanks for help
