Hey everybody,
is it possible to set in LibeNMS an default behavior for alerting ports?
I wish to have an workflow like this:
- I add an Switch to LibreNMS and the alerting tag is for every port off.
- For the really important ports, I enable the alerting tag for the specific ports
So is it possible to set it up, that when I add an switch, the alerting tags for the ports are ALL off. And I can set them manually on later, but just for the specific ports.
Best regards
Luca
