I’ve got a Dell r710 with idrac module installed. The module is discovered in librenms, but I have no graphs of anything. I have attempted a rediscovery a couple of times. This is quite possibly newbie error. Are there any suggestions as to what I should try?
I’ve got a number of other devices that are properly discovered.
The following are my librenms details:
Version 807ca16 - Tue Nov 15 2016 21:38:04 GMT+0000
DB Schema #149
Web Server Apache/2.4.7 (Ubuntu)
PHP 5.5.9-1ubuntu4.20
MySQL 5.5.52-MariaDB-1ubuntu0.14.04.1
RRDtool 1.4.7
I have to admit that the first run of validate.php did return a number of error messages. I therefore ran through the installation and made some changes here and there (most relevant of which was probably /etc/snmp/snmp.conf).
I now do have two graphs called as follow: “This attribute defines the overall chassis status” and “This attribute defines type of a remote access card”.
I had hoped for graphs on temperature, fan speed, power and such like, but maybe that isn’t available? I’ve run a “Capture Debug Information” on the discovery of it, maybe it is of some relevance?
I’ve now configured librenms to poll the idrac using IPMI and I’m now getting the data I was after. Still somewhat surprised the data doesn’t seem to be exposed via SNMP.
