Device group Maps and Network Maps are broken
My device group maps and network Maps are no longer showing devices and only the interconnects.
This is my validate.php
LibreNMS | 1.42.01-11-gabd2c63
DB Schema | 258
PHP | 7.0.30-0ubuntu0.16.04.1
MySQL | 10.0.34-MariaDB-0ubuntu0.16.04.1
RRDTool | 1.5.5
SNMP | NET-SNMP 5.7.3
[OK] Composer Version: 1.7.0
[FAIL] Database: incorrect column (notifications/datetime)
[FAIL] Database: incorrect column (users/created_at)
[FAIL] We have detected that your database schema may be wrong, please report the following to us on IRC or the community site (Report database schema issues here - LibreNMS Community):
SQL Statements:
ALTER TABLE notifications CHANGE datetime datetime timestamp NOT NULL DEFAULT ‘1970-01-02 00:00:00’ ;
ALTER TABLE users CHANGE created_at created_at timestamp NOT NULL DEFAULT ‘1970-01-02 00:00:01’ ;
Modified Files:
includes/defaults.inc.php
I have previously modified the defaults.inc.php to include a bunch of bad.if and I copied it back. I’m not quite sure how to get back to the newest version of defaults.inc.php but running a diff of both files, I don’t think that’s the problem.
Any help please?
Thanks in advance!
OK, for anyone who’s run into this again, this is what i did to fix it:
/opt/librenms/scripts$ sudo ./github-remove -d
Are you sure you want to delete all modified and untracked files? [y/N] y
Removing html/includes/print-menubar-custom.inc.php
Removing includes/defaults.inc.php.bkup
Removing includes/defaults.inc.php.custom.bkup
then:
/opt/librenms$ sudo ./daily.sh
And now its fixed!
Now time to put my custom bad if files into my config.php instead…
Always put your bad ifs into the config file.
Don’t modify the defaults.inc.php
I’m currently having the exact same issue for the network map. I have other device group maps that work just fine though. This has been occurring for maybe for a week or so. The solution posted by Sy_Na does not help.
My validate.php:
LibreNMS | 1.53.1-20-g71da38c
DB Schema | 2019_05_30_225937_device_groups_rewrite (135)
PHP | 7.2.16
MySQL | 5.5.60-MariaDB
RRDTool | 1.4.8
SNMP | NET-SNMP 5.7.2
[OK] Composer Version: 1.8.6
And in my config.php, the ignored interfaces:
# ignore interfaces
$config[‘bad_if_regexp’][] = '/^em./’;*
$config[‘bad_if_regexp’][] = '/^dsc./’;*
$config[‘bad_if_regexp’][] = '/^tap./’;*
$config[‘bad_if_regexp’][] = '/^gre./’;*
$config[‘bad_if_regexp’][] = '/^ipip./’;*
$config[‘bad_if_regexp’][] = '/^pime./’;*
$config[‘bad_if_regexp’][] = '/^pimd./’;*
$config[‘bad_if_regexp’][] = '/^mtun./’;*
$config[‘bad_if_regexp’][] = '/^demux./’;*
$config[‘bad_if_regexp’][] = '/^cpb./’;*
$config[‘bad_if_regexp’][] = '/^pip./’;*
$config[‘bad_if_regexp’][] = '/^pp./’;*
$config[‘bad_if_regexp’][] = '/^vme./’;*
$config[‘bad_if_regexp’][] = '/^ptp0./’;*
And I’m using xdp:
$config[‘network_map_items’] = array(‘xdp’);
Any help would be greatly appreciated!
Looks like network maps are working again without issue. Not sure why/how.
Fix was merged into the daily build. Thank you to rmedlyn
