Hi, I have issue when monitoring iDRAC sensor, only sensor below had error and not showing
Memory Usage : not showing
Processor Usage : Drawing Error
only iDrac have issue for graph, else (local device, fortigate) are working properly, does any one have same issue like this, kindly need your share how to solve this issue, thanks
[[email protected] ~]$ git pull
warning: Pulling without specifying how to reconcile divergent branches is
discouraged. You can squelch this message by running one of the following
commands sometime before your next pull:
git config pull.rebase false # merge (the default strategy)
git config pull.rebase true # rebase
git config pull.ff only # fast-forward only
You can replace “git config” with “git config --global” to set a default
preference for all repositories. You can also pass --rebase, --no-rebase,
or --ff-only on the command line to override the configured default per
invocation.
Already up to date.
[[email protected] ~]$ ./daily.sh
Updating Composer packages OK
Updating SQL-Schema OK
Updating submodules OK
Cleaning up DB OK
Fetching notifications OK
Caching PeeringDB data OK
[[email protected] ~]$ ./validate.php
Component | Version |
LibreNMS | 21.3.0-103-gc46479753 |
DB Schema | 2021_04_08_151101_add_foreign_keys_to_port_group_port_table (208) |
PHP | 7.3.20 |
Python | 3.6.8 |
MySQL | 10.3.27-MariaDB |
RRDTool | 1.7.0 |
SNMP | NET-SNMP 5.8 |
[OK] Composer Version: 2.0.12
Regards,
GPN
