Dear all,
I have a network of up to 2000 devices, and I am having some troubles since most of the devices are not polling correctly.
Below there is represented my cron.job file:
I have to comment that I have set the ping check to 1 minute and my fping configuration is the following:
I set ping_rrd_step
$config[‘ping_rrd_step’] = 60;
,updated the rrd files
./scripts/rrdstep.php -h all
and also the cron:
* * * * * librenms /opt/librenms/ping.php >> /dev/null 2>&1
Finally, I update the config.php:
$config['fping'] = "/usr/sbin/fping";
$config['fping_options']['timeout'] = 500;
$config['fping_options']['count'] = 5;
$config['fping_options']['interval'] = 500;
Furthermore, when I check the validation file (validate.php), these are the results:
I have checked the cron job and anything seems to setup incorrectly. Moreover, in the web UI in the poll-log I see the pooler is updating every minute, so I do not know how to solve it and I am a bit lost. I will be very grateful if someone could help me.
Best regards,
Sebastia
