I’ve added 37 devices that are all working and showing correctly. One device, a Mikrotik CCR router is showing a funky port speed on it’s internet port. It’s a 1g port but it has several spots where it’s showing 43-190gb of traffic. Again, this is on a 1g port. Since this spike is there, I can’t see the actual speed being reported, which should be around 400mb.If I change the timeframe window to the last hour only, I can see the real speed on that port. If I go to the last day, it just shows that 43+gig spike and since that spike is so large, the real speeds can’t be seen. How can I fix this? Is there a way to delete the data in the rrd file and recreate it? I’m ok if I lose the historical data as this device has only been there for a day or so.
EDIT: Just wanted to point out that I have another CCR that’s graphing correctly with no spikes.
See if below FAQ helps
why-do-i-see-traffic-spikes-in-my-graphs
Thank you for the reply. I read through this and it was already set under Global Settings. I did go ahead and enable in Device>Edit>Misc>Enable RRD Tune for all ports, just in case it wasn’t getting it from the global settings. I’ll wait and see what happens.
