Device Ports page - delay loading due to slow DB query
Hello.
I’ve noticed some odd behaviour on the Device Ports page (e.g. /device/1/ports) where there is a considerable delay on page load. I’ve done some digging and it happens regardless of the number of interfaces - it looks like this delay is caused by a slow database query when pulling the ports_vlans for the connected interfaces:
# Time: 240930 13:32:26
# User@Host: librenms[librenms] @  [127.0.0.1]
# Thread_id: 7317  Schema: librenms  QC_hit: No
# Query_time: 3.805417  Lock_time: 0.000009  Rows_sent: 0  Rows_examined: 6832053
# Rows_affected: 0  Bytes_sent: 0
SET timestamp=1727703146;
select * from `ports_vlans` where `ports_vlans`.`port_id` in (47546, 11533011, 11533808, 11564043, 11564044);
The explain output shows that it’s doing a full table scan instead of using the ports_vlans index:
MariaDB [librenms]> explain select * from `ports_vlans` where `ports_vlans`.`port_id` in (47546, 11533011, 11533808, 11564043, 11564044);
| id   | select_type | table       | type | possible_keys | key  | key_len | ref  | rows    | Extra       |
|    1 | SIMPLE      | ports_vlans | ALL  | NULL          | NULL | NULL    | NULL | 6805422 | Using where |
I’m not sure where in the app that this query is generated, but just wondering if anyone has noticed something similar? I have around 77k ports across ~1500 devices so I guess this is something related to the size of install?
Validate output below:
$ ./validate.php
LibreNMS  | 24.9.1-1-gdbfb0a6535 (2024-09-30T00:18:17+00:00)
DB Schema | 2024_03_27_123152_create_transceivers_table (300)
PHP       | 8.3.6
Python    | 3.12.3
Database  | MariaDB 10.11.8-MariaDB-0ubuntu0.24.04.1-log
SNMP      | 5.9.4.pre2
Any pointers or help appreciated.
Cheers.
We probably need to add an index to that table then. The query is really simple so no way we can optimise the query itself
Out of interest, have you updated to the latest version and if so, how does the new VLAN page work for you?
Hey laf,
Thanks for coming back to me. I’ve ran an update and now on LibreNMS 24.9.1-4-g2531c8d (2024-09-30T23:39:15+00:00) - I think that’s me pretty much up to date?
Would it make sense to limit the query to search by device_id as well as port_ids? That appears to use the indexes already in place (ports_vlans_device_id_port_id_vlan_unique) and returns faster on my install compared to the plain port_id search.
Looking at an explain it changes it from scanning 7m rows to 5:
MariaDB [librenms]> explain select * from `ports_vlans` where `ports_vlans`.`port_id` in (47546, 11533011, 11533808, 11564043, 11564044) and `ports_vlans`.`device_id` =
 1;
|    1 | SIMPLE      | ports_vlans | range | ports_vlans_device_id_port_id_vlan_unique | ports_vlans_device_id_port_id_vlan_unique | 8       | NULL | 5    | Using index condition |
1 row in set (0.000 sec)
I’ve tried to have a look in the code base to see where this query is generated but I’m not that familiar with Laravel so it’s not entirely obvious to me.
I’ll need to take a look at the new global vlan page.
Cheers.
Following up on my own question: I added an index for the port_id column on the ports_vlans table as a test and that appears to have helped massively - dropping the average query time from seconds to milliseconds.
ports_vlans_device_id_port_id_vlan_unique can’t be used because device_id is not used in the query. So, yes, a new index is needed.
The query is a basic relationship query and is initiated here and here:
Here is the relationship definition
Hi Tony, thanks for the explanation and pointers - appreciated.
I can also see that the table schema updated overnight and added in 2024_10_06_002633_ports_vlans_table_add_port_id_index - that’s really helpful, thanks!
