In our network we use Out-Of-Band & In-Band Per Switch, is it possible to have an option to enable per device? it would be like a fall back it will do just ICMP request and SNMP check (just reachability) on the secondary IP, no polling and if the primary IP fails it goes to the secondary and we can trigger an alert.
Thanks.
