I’ve noticed in the last week or so, some devices are taking a long time to alert as offline.
For example, we powered off a device this morning and I’m unable to snmpwalk or ping the device (confirming it is offline), however it simply sits in the “Poller” section in Validate.php for a while (about 30 minutes) advising that polling took longer than 5 minutes.
Our down alert rule has no delays on alerting.
We use the new LibreNMS ‘dispatcher’ Service in a cluster (managed by Redis, the 3 dispatcher pollers are in the same group, the example device is in this poller group)
$ ./validate.php
Component | Version |
LibreNMS | 1.60-18-g19a82e150 |
DB Schema | 2020_02_05_224042_device_inserted_null (158) |
PHP | 7.2.24-0ubuntu0.18.04.2 |
MySQL | 10.1.44-MariaDB-0ubuntu0.18.04.1 |
RRDTool | 1.7.0 |
SNMP | NET-SNMP 5.7.3 |
[OK] Composer Version: 1.9.3
Devices:
<REDACTED.HOSTNAME>
