Maybe I’m not wording my query very well but I can’t seem to find quite what I’m looking for (I’m a bit new to some of this)
I have LibreNMS working with InfluxDB and Grafana. I don’t necessarily need the solution to end up on Grafana but I suspect that with better understanding, that will start to fall into place.
First - If I just wanted a dashboard that showed me a list of the devices that are down at the moment, how would I go about this? Component Status doesn’t seem to give me ANY information, Device Summary is… helpful but too broad. After some searching, I found some macros that would seem to indicate that the up/down state for a device is stored or determined and I would think it would be available to use either in the dashboards or as a datapoint being sent to grafana, but the only indication I can find that this info is being looked at is in either a query or the device summary (it shows the down count, I would assume there’s an expanded version of that?)
Second - (sort of as a workaround maybe) how are the fields being populated in Influx determined by LibreNMS? Seems like there’s a set list with very little in the way of flexibility. Basically, same issue as the First point/question - how dow I get just the up/down state? I don’t need an alert yet, right now I just want to be able to list it out in a dashboard either in grafana or librenms (ideally both).
I’m a little short on time to write this, so I apologize if the details are a bit sparse - I’m not really time constrained to solve it, just to write this post ![]()
I feel like I’m missing something obvious but it’s just out of reach…
