We are using LibreNMS on our server. Suddenly, the disk was full. So we have increased disk size and ran ./daily.sh script. but now no devices are showing in LibreNMS panel. Can you please let me know how to fix this issue. We have attached screenshot, please check
Thank you!
What is the output of ./validate.php
Is the partition on which the RRD files live the one you grew?
[root@librenms librenms]# ./validate.php
Component |
Version |
LibreNMS |
1.64.1-248-gdba7daa |
DB Schema |
2020_06_23_00522_alter_availability_perc_column (170) |
PHP |
7.2.10 |
Python |
3.6.8 |
MySQL |
5.5.60-MariaDB |
RRDTool |
1.4.8 |
SNMP |
NET-SNMP 5.7.2 |
[OK] Composer Version: 1.10.8
Modified Files:
html/js/L.Control.Locate.min.js
html/js/L.Control.Locate.min.js.map
html/js/Leaflet.GoogleMutant.js
html/js/RrdGraphJS/DragCursor.cur
html/js/RrdGraphJS/MoveCursor.cur
html/js/RrdGraphJS/moment-timezone-with-data.js
html/js/RrdGraphJS/q-5.0.2.min.js
html/js/RrdGraphJS/rrdGraphPng.js
html/js/app.js
html/js/boot.js
html/js/bootstrap-datetimepicker.min.js
html/js/bootstrap-hover-dropdown.min.js
html/js/bootstrap-switch.js
html/js/bootstrap-switch.min.js
html/js/bootstrap.js
and 88 more…
Are those files you created yourself?
Nope , we have not created those files by ourself.
Then you can run the github script to remove those files. You want to end up with a clean validate.php for a start, and then take it from there.
Thanks a lot . it worked
./scripts/github-remove -d
./validate.php
I am glad it worked. Think it would be good if you could mark this as solved?
