Devices shows no devices, but they are there!
LibreNMS  | 24.6.0 (2024-07-31T04:07:13+01:00)
DB Schema | 2021_02_09_122930_migrate_to_utf8mb4 (294)
PHP       | 8.2.20
Python    | 3.11.9
Database  | MariaDB 11.5.2-MariaDB-ubu2404
RRDTool   | 1.8.0
SNMP      | 5.9.4
[OK]    Installed from the official Docker image; no Composer required
[OK]    Redis is unavailable
[WARN]  IPv6 is disabled on your server, you will not be able to add IPv6 devices.
[OK]    rrd_dir is writable
[WARN]  Updates are managed through the official Docker image
Just setup LibreNMS in a Docker container through unraid.
It’s running, and I have managed to add devices, but when I click on the devices menu, the system shows no devices.
If I goto http://ipofserver:8000/devices, I see the devices I have added no problem.
Any ideas why the menu option doesn’t take me to the devices screen?
I have this running in a VM at the moment, and wanted to migrate to a dockerised install, but cant figure this bit out.
type or paste code here
