Devices unpolled
I need a help, my server stop polling with error;
Devices unpolled
It appears as though you have some devices that haven't completed polling within the last 15 minutes, you may want to check that out :)
Any idea to solve it please!
librenms@ubuntu:~$ ./validate.php
LibreNMS  | 24.8.0-28-gcdc360dcd (2024-08-28T20:35:20+01:00)
DB Schema | 2024_08_27_182000_ports_statistics_table_rev_length (299)
PHP       | 8.2.22
Python    | 3.10.12
Database  | MariaDB 10.6.18-MariaDB-0ubuntu0.22.04.1
SNMP      | 5.9.1
[OK]    Composer Version: 2.7.8
[FAIL]  Poller is not running.  No poller has run within the last 300 seconds.
[FAIL]  No active python wrapper pollers found
[OK]    Redis is unavailable
librenms@ubuntu:~$ /opt/librenms/poller-wrapper.py 4
2024-08-30 12:16:02,155 :: CRITICAL :: ERROR: Could not connect to MySQL database! (1130, "127.0.0.1' is not allowed to connect to this MariaDB server")
Traceback (most recent call last):
  File "/opt/librenms/poller-wrapper.py", line 64, in <module>
    wrapper.wrapper(
  File "/opt/librenms/LibreNMS/wrapper.py", line 468, in wrapper
    db_connection = LibreNMS.DB(sconfig)
  File "/opt/librenms/LibreNMS/__init__.py", line 220, in __init__
    self.connect()
  File "/opt/librenms/LibreNMS/__init__.py", line 269, in connect
    conn = MySQLdb.connect(**args)
  File "/usr/lib/python3/dist-packages/pymysql/connections.py", line 353, in __init__
    self.connect()
  File "/usr/lib/python3/dist-packages/pymysql/connections.py", line 632, in connect
    self._get_server_information()
  File "/usr/lib/python3/dist-packages/pymysql/connections.py", line 1055, in _get_server_information
    packet = self._read_packet()
  File "/usr/lib/python3/dist-packages/pymysql/connections.py", line 725, in _read_packet
    packet.raise_for_error()
  File "/usr/lib/python3/dist-packages/pymysql/protocol.py", line 221, in raise_for_error
    err.raise_mysql_exception(self._data)
  File "/usr/lib/python3/dist-packages/pymysql/err.py", line 143, in raise_mysql_exception
    raise errorclass(errno, errval)
pymysql.err.OperationalError: (1130, "127.0.0.1' is not allowed to connect to this MariaDB server")
I can connect to db normally!
root@ubuntu:~# mysql
Welcome to the MariaDB monitor.  Commands end with ; or \g.
Your MariaDB connection id is 8951
Server version: 10.6.18-MariaDB-0ubuntu0.22.04.1 Ubuntu 22.04
Copyright (c) 2000, 2018, Oracle, MariaDB Corporation Ab and others.
Type 'help;' or '\h' for help. Type '\c' to clear the current input statement.
MariaDB [(none)]> show databases;
| Database           |
| information_schema |
| librenms           |
| mysql              |
| performance_schema |
| sys                |
5 rows in set (0.000 sec)
MariaDB [(none)]>
In your database connection test, you did not use the same credentials and settings LibreNMS used.
Hi @murrant Thanks for your response.
I’m trying a thousand ways to restore or recreate the new poller, but it doesn’t work, the system has access to the hosts and all the settings, this proves that there is communication with the database, but I still haven’t figured out how to solve the polling error problem on my system, is there any way to recreate it? Please can you help me!
What is the solution?
It seems this happened to lots of people on the midnight update - FAIL: Poller is not running. No poller has run within the last 300 seconds
Are you running as a single poller or in distributed ?
