Hi guys.
My lnms platform is properly collecting and creating graphs for dhcp leases current and max values.
Is it possible to create an alert , for example when current value is 85% of the max.
Any idea ?
Regards.
Leandro.
Have a look @ https://docs.librenms.org/Alerting/Rules/ It describes how to make custom alert by querying the db, I’m not SQL-savvy enough to make a query for dhcp lease, but there are examples for querying other stuff you might find helpful.
I will check it … anyway , do you know where is the dhcp info in the database ? I can see on graphs but dont know where is that info in the db.
