Hi
is it possible to activate a direct http / https check from the LibreNMS against a remote server,
without use snmp or remote agents, collecting the response time for graphs ?
If not yet, can you consider to add this feature ?
Thanks regards
I.
Hi
Thanks regards
I.
Hi Ivan,
LibreNMS can do this through Services. You can add a http-Service to your device and test whether the webpage is reachable (Status 200). Here’s an example of how to configure it:
Hope this helps.
Lucas
Hi Lucas
many thanks for the reply, we will try and post the result.
Regards
I.
