Hi all,
Not sure of the correct syntax.
I want to disable some discovery modules that we don’t need.
The docs say this can be done, but I’m not sure of the correct syntax to put in config.php.
Can anyone point me at the correct doc?
Hi all,
For all devices? http://docs.librenms.org/Support/Discovery%20Support/#discovery-config
Per OS: http://docs.librenms.org/Support/Discovery%20Support/#os-based-discovery-config
Per device is done in edit device -> modules
Thanks @laf spot on as usual
