does a way existe to disable the mouseover minigraph in the device menu for host ? i try the lnms config:set web_mouseover false with no luck … Is it something hardcoded ?
I
I
Which graph or link is this happening on as I’ve set lnms config:set web_mouseover false and don’t get the mouseover graphs anymore.
the mini graph when your mouse pointer pass by the device hostname ,… it shows 3 mini graph…
Found a workaround.
In storage/framework/views find the file containing the tw-inline-block and comment it out … after that disable the daily updates
I did try the option lnms congif set: web_mouseover false on OL8 and Debian11 with no luck
hope this help some folks
