Hi.
All off the sudden I’m having issues to add a new device from specific vendor.
It has worked before. It has been detected as “generic device”.
Now it seems like that discovery fails when adding new device.
When triggering discovery to device of same model and firmware that has been added before, it works just fine. When triggering discovery to new device I get error messege.
Output from discovery Untitled - LibreNMS
Any suggestions?
Also providing discovery-log below.
LibreNMS Discovery
SQL[[1;33mselect migration
from migrations
order by id
desc limit 1 [0;33m[0m 0.49ms]
SQL[[1;33mselect count(*) as aggregate from migrations
[0;33m[0m 0.36ms]
SQL[[1;33mselect version() [0;33m[0m 0.28ms]
Component | Version |
LibreNMS | 22.10.0-64-gce6eaadc2 (2022-11-02T22:54:40+01:00) |
DB Schema | 2022_08_15_084507_add_rrd_type_to_wireless_sensors_table (248) |
PHP | 8.1.11 |
Python | 3.8.10 |
Database | MariaDB 10.3.34-MariaDB-0ubuntu0.20.04.1 |
RRDTool | 1.7.2 |
SNMP | 5.8 |
DEBUG! | |
Updating os_def.cache | |
SQL[[1;33mSELECT * FROM devices WHERE disabled = 0 AND hostname LIKE ‘10.0.0.161’ ORDER BY device_id DESC [0;33m[0m 0.88ms] |
SQL[[1;33mselect * from devices
where device_id
= ? limit 1 [0;33m[161][0m 0.48ms]
SQL[[1;33mselect * from devices_attribs
where devices_attribs
.device_id
= ? and devices_attribs
.device_id
is not null [0;33m[161][0m 0.27ms]
10.0.0.161 161 generic [FPING] ‘/usr/bin/fping’ ‘-e’ ‘-q’ ‘-c’ ‘3’ ‘-p’ ‘500’ ‘-t’ ‘500’ ‘-O’ ‘0’ ‘10.0.0.161’
response: xmt/rcv/%loss = 3/3/0%, min/avg/max = 0.34/0.46/0.54
SNMP[[0;36m’/usr/bin/snmpget’ ‘-M’ ‘/opt/librenms/mibs’ ‘-v2c’ ‘-c’ ‘COMMUNITY’ ‘-OQXUte’ ‘-r’ ‘4’ ‘udp:HOSTNAME:161’ ‘SNMPv2-MIB::sysObjectID.0’[0m]
SNMPv2-MIB::sysObjectID.0 = SNMPv2-SMI::enterprises.9304.100.5152
Modules status: Global+
OS
Device
Load disco module core
Attempting to initialize OS: generic
OS initialized: LibreNMS\OS\Generic
SNMP[[0;36m’/usr/bin/snmpget’ ‘-M’ ‘/opt/librenms/mibs’ ‘-v2c’ ‘-c’ ‘COMMUNITY’ ‘-OQXUte’ ‘-On’ ‘-r’ ‘4’ ‘udp:HOSTNAME:161’ ‘SNMPv2-MIB::sysObjectID.0’ ‘SNMPv2-MIB::sysDescr.0’ ‘SNMPv2-MIB::sysName.0’[0m]
...0 = ..4.1.9304.100.5152
...0 = FOS-5152-2A Version 1.00.0W
..*.0 = Skolan_1222_1C
| FOS-5152-2A Version 1.00.0W | .1.3.6.1.4.1.9304.100.5152 |
SNMP[[0;36m’/usr/bin/snmpget’ ‘-M’ ‘/opt/librenms/mibs:/opt/librenms/mibs/arris’ ‘-v2c’ ‘-c’ ‘COMMUNITY’ ‘-OQXUte’ ‘-r’ ‘4’ ‘udp:HOSTNAME:161’ ‘.1.3.6.1.4.1.1166.1.621.14.2.0’[0m]
iso..1.1166.1.6 = No Such Object available on this agent at this OID
SNMP[[0;36m’/usr/bin/snmpget’ ‘-M’ ‘/opt/librenms/mibs’ ‘-v2c’ ‘-c’ ‘COMMUNITY’ ‘-OQXUte’ ‘-r’ ‘4’ ‘udp:HOSTNAME:161’ ‘.1.3.6.1.4.1.8072.1.3.2.3.1.2.6.100.105.115.116.114.111’[0m]
iso..1.8...114.111 = No Such Object available on this agent at this OID
SNMP[[0;36m’/usr/bin/snmpget’ ‘-M’ ‘/opt/librenms/mibs:/opt/librenms/mibs/eltek’ ‘-v2c’ ‘-c’ ‘COMMUNITY’ ‘-OQXUte’ ‘-r’ ‘4’ ‘udp:HOSTNAME:161’ ‘.1.3.6.1.4.1.12148.10.2.6.0’[0m]
iso..1.12.0 = No Such Object available on this agent at this OID
SNMP[[0;36m’/usr/bin/snmpget’ ‘-M’ ‘/opt/librenms/mibs:/opt/librenms/mibs/hikvision’ ‘-v2c’ ‘-c’ ‘COMMUNITY’ ‘-OQXUte’ ‘-r’ ‘4’ ‘udp:HOSTNAME:161’ ‘.1.3.6.1.4.1.39165.1.1.0’[0m]
iso..1.39 = No Such Object available on this agent at this OID
SNMP[[0;36m’/usr/bin/snmpget’ ‘-M’ ‘/opt/librenms/mibs:/opt/librenms/mibs/orvaldi’ ‘-v2c’ ‘-c’ ‘COMMUNITY’ ‘-OQXUte’ ‘-r’ ‘4’ ‘udp:HOSTNAME:161’ ‘.1.3.6.1.4.1.21111.1.1.1.6.0’[0m]
iso..1.21.6.0 = No Such Object available on this agent at this OID
SNMP[[0;36m’/usr/bin/snmpget’ ‘-M’ ‘/opt/librenms/mibs’ ‘-v2c’ ‘-c’ ‘COMMUNITY’ ‘-OQXUte’ ‘-r’ ‘4’ ‘udp:HOSTNAME:161’ ‘1.3.6.1.4.1.4515.1.3.6.1.1.1.2.0’[0m]
iso..1.45.*.0 = No Such Object available on this agent at this OID
SNMP[[0;36m’/usr/bin/snmpget’ ‘-M’ ‘/opt/librenms/mibs:/opt/librenms/mibs/primekey’ ‘-v2c’ ‘-c’ ‘COMMUNITY’ ‘-OQXUte’ ‘-r’ ‘4’ ‘udp:HOSTNAME:161’ ‘PRIMEKEY-APPLIANCE-MIB::pkAVersion’[0m]
PRIMEKEY-APPLIANCE-MIB::pkAVersion = No Such Object available on this agent at this OID
SNMP[[0;36m’/usr/bin/snmpget’ ‘-M’ ‘/opt/librenms/mibs:/opt/librenms/mibs/wisi’ ‘-v2c’ ‘-c’ ‘COMMUNITY’ ‘-OQXUte’ ‘-r’ ‘4’ ‘udp:HOSTNAME:161’ ‘.1.3.6.1.4.1.7465.20.2.9.1.2.1.3.1.2’[0m]
iso..1.74.*.1.2 = No Such Object available on this agent at this OID
OS: Generic Device (generic)
Runtime for discovery module ‘core’: 0.3610 seconds with 712 bytes
[0;36mSNMP[0m: [9/0.34s] [1;33mMySQL[0m: [0/0.00s] [0;32mRRD[0m: [0/0.00s]
Unload disco module core
OS
Device
Load disco module os
Yaml location data:
SNMP[[0;36m’/usr/bin/snmpget’ ‘-v2c’ ‘-c’ ‘COMMUNITY’ ‘-Oqv’ ‘-M’ ‘/opt/librenms/mibs’ ‘-r’ ‘4’ ‘udp:HOSTNAME:161’ ‘SNMPv2-MIB::sysLocation.0’[0m]
Gotafors_Skola,Vaggeryd
SQL[[1;33mselect * from locations
where (location
= ?) limit 1 [0;33m[“Gotafors_Skola,Vaggeryd”][0m 0.61ms]
::query() failed: DNS request failed: The domain name referenced in the query does not exist.
OpenStreetMap geocode engine
Fatal error: Declaration of App\ApiClients\NominatimApi::parseLatLng(array $data): array must be compatible with App\ApiClients\GeocodingHelper::parseLatLng($data) in /opt/librenms/app/ApiClients/NominatimApi.php on line 40
Declaration of App\ApiClients\NominatimApi::parseLatLng(array $data): array must be compatible with App\ApiClients\GeocodingHelper::parseLatLng($data) {“exception”:“[object] (Symfony\Component\ErrorHandler\Error\FatalError(code: 0): Declaration of App\ApiClients\NominatimApi::parseLatLng(array $data): array must be compatible with App\ApiClients\GeocodingHelper::parseLatLng($data) at /opt/librenms/app/ApiClients/NominatimApi.php:40)”}
In NominatimApi.php line 40:
