Hey everyone,
New to LibreNMS. I did a search for Cisco IP Phones on the forum, but couldn’t find any other threads about this. The documentation indicates that by default discovery is disabled for Cisco IP Phones via XDP. However, when running discovery.php -d, I’m seeing attempts to poll these devices as they’re discovered. Here’s a sample from one of the discovery attempts.
Any feedback or guidance will be greatly appreciated!
Thanks!
-Blake
.SQL[SELECT * FROM
portsWHEREdevice_id= ? ANDifIndex= ? [18,10137] 1.49ms]array (
‘cdpCacheAddressType’ => ‘1’,
‘cdpCacheAddress’ => ‘0A 1E 14 3A’,
‘cdpCacheVersion’ => ‘SCCP42.9-3-1SR2-1S’,
‘cdpCacheDeviceId’ => ‘SEP1CAA071049B8’,
‘cdpCacheDevicePort’ => ‘Port 1’,
‘cdpCachePlatform’ => ‘Cisco IP Phone 7962’,
‘cdpCacheCapabilities’ => ‘00 00 04 90’,
‘cdpCacheNativeVLAN’ => ‘0’,
‘cdpCacheDuplex’ => ‘3’,
‘cdpCacheLastChange’ => ‘3434833279’,
SQL[SELECTdevice_idFROMdevicesWHEREsysName=? ORhostname=? ORhostname=? ORip=? [“SEP1CAA071049B8”,“SEP1CAA071049B8”,{“ip”:“10.30.20.58”,“cidr”:32,“host_bits”:32},"\n\u001discovering SEP1CAA071049B8
name lookup of SEP1CAA071049B8 failed
SQL[insert intoeventlog(device_id,reference,type,datetime,severity,message,username) values (?, ?, ?, ?, ?, ?, ?) [18,null,“discovery”,“2020-06-20 18:51:35”,5,"CDP ddiscovering 10.30.20.58
ip lookup result: 10.30.20.58
SQL[SELECT COUNT(*) FROMdevicesWHEREhostname=? [“10.30.20.58”] 1.61ms]SQL[select * from
ipv4_addresseswhereipv4_address= ? limit 1 [“10.30.20.58”] 2.01ms][FPING] ‘/usr/sbin/fping’ ‘-e’ ‘-q’ ‘-c’ ‘3’ ‘-p’ ‘500’ ‘-t’ ‘500’ ‘10.30.20.58’
response: {“xmt”:3,“rcv”:3,“loss”:0,“min”:2.01,“max”:2.1,“avg”:2.04,“dup”:0,“exitcode”:0}
SNMP Check response code: 1
SNMP[‘/usr/bin/snmpget’ ‘-v2c’ ‘-c’ ‘COMMUNITY’ ‘-Oqv’ ‘-m’ ‘SNMPv2-MIB’ ‘-M’ ‘/opt/librenms/mibs’ ‘udp:HOSTNAME:161’ ‘sysObjectID.0’]Timeout: No Response from udp:10.30.20.58:161.
SNMP[‘/usr/bin/snmpget’ ‘-v3’ ‘-l’ ‘noAuthNoPriv’ ‘-n’ “” ‘-u’ ‘USER’ ‘-Oqv’ ‘-m’ ‘SNMPv2-MIB’ ‘-M’ ‘/opt/librenms/mibs’ ‘udp:HOSTNAME:161’ ‘sysObjectID.0’]snmpget: Timeout (Sub-id not found: (top) → sysObjectID)
SNMP[‘/usr/bin/snmpget’ ‘-v1’ ‘-c’ ‘COMMUNITY’ ‘-Oqv’ ‘-m’ ‘SNMPv2-MIB’ ‘-M’ ‘/opt/librenms/mibs’ ‘udp:HOSTNAME:161’ ‘sysObjectID.0’]Timeout: No Response from udp:10.30.20.58:161.
SQL[insert intoeventlog(device_id,reference,type,datetime,severity,message,username) values (?, ?, ?, ?, ?, ?, ?) [18,null,“discovery”,“2020-06-20 18:52:12”,5,"CDP dDiscover link: 1119, cdp, 0, SEP1CAA071049B8, Port 1, Cisco IP Phone 7962, SCCP42.9-3-1SR2-1S,
SQL[SELECT COUNT(*) FROMlinksWHEREremote_hostname= ? ANDlocal_port_id= ? ANDprotocol= ? ANDremote_port= ? [“SEP1CAA071049B8”,1119,“cdp”,“Port 1”] 1.72ms]SQL[SELECT
id,local_device_id,remote_platform,remote_version,remote_device_id,remote_port_idFROMlinksWHEREremote_hostname= ? ANDlocal_port_id= ? ANDprotocol= ?
