Everytime i run discovery.php or the discovery wrapper or addhost.php or snmp-scan.py, i get this error.
Scanned som-host-fqdn (10.52.0.9) array_intersect_key(): Argument #1 ($array) must be of type array, string given {"exception"
:"[object] (TypeError(code: 0): array_intersect_key(): Argument #1 ($array) must be of type array, string given at /opt/librenms/vendor/laravel/fr
amework/src/Illuminate/Collections/Arr.php:435)"}
In Arr.php line 435:
Audodiscovery is also not working because of this. i have tried this on ubuntu 20.x and 22.x running php8.1.
I can add host via the web GUI without issues
Note: Everything works fine if i siwitch to using php7.4
Follow the docs and install librenms on ubuntu with php8.1
su - librenns
cd /opt/librenms
./scan-scan.py 192.168.1.1/32 or wtv cider
./addhost.php xyz
