we have recently upgraded ubuntu from 20.04 to 22.04, (no change in LibreNMS) post which I’m getting below error while running discovery wrapper script.
Can you please help here? what could be the possible issue here?
root@b65inflrenms05:/home/ubuntu# docker exec librenms_dispatcher sh -c ‘/opt/librenms/discovery-wrapper.py 32’
Traceback (most recent call last):
File “/opt/librenms/discovery-wrapper.py”, line 64, in
wrapper.wrapper(
AttributeError: module ‘LibreNMS.wrapper’ has no attribute ‘wrapper’
Below is the output for validate.php ::::::::::::::::
librenms-dispatcher:/opt/librenms$ ./validate.php
| LibreNMS | 23.11.0 (2023-11-25T19:17:34+00:00) |
| DB Schema | 2023_11_04_125846_packages_increase_name_column_length (273) |
| PHP | 8.1.22 |
| Python | 3.10.13 |
| Database | MariaDB 10.5.24-MariaDB-1:10.5.24+maria~ubu2004 |
| RRDTool | 1.7.2 |
| SNMP | 5.9.3 |
[OK] MySQl and PHP time match
[WARN] Using database for locking, you should set CACHE_DRIVER=redis
[FAIL] Scheduler is not running
sudo cp /opt/librenms/dist/librenms-scheduler.cron /etc/cron.d/
