LibreNMS Discovery
SQL[SELECT version FROM dbSchema
ORDER BY version DESC LIMIT 1]
SQL[SELECT version()]
Version info:
Commit SHA: abd2c6363f2b08523ff95c1f4786eb66cd2fa618
Commit Date: 1533566256
DB Schema: 258
PHP: 7.2.6
MySQL: 5.5.56-MariaDB
RRDTool: 1.4.8
SNMP: NET-SNMP 5.7.2
Updating os_def.cache… Done
SQL[SELECT * FROM devices
WHERE disabled = 0 AND snmp_disable = 0 AND hostname
LIKE ‘192.168.3.59’ ORDER BY device_id DESC]
SQL[SELECT * FROM devices_attribs WHERE device_id
= ‘25’]
192.168.3.59 25 linux SQL[INSERT INTO device_perf
(xmt
,rcv
,loss
,min
,max
,avg
,device_id
,timestamp
) VALUES (‘3’,‘3’,‘0’,‘0.61’,‘0.66’,‘0.63’,‘25’,NOW())]
SNMP Check response code: 0
SQL[SELECT attrib_value FROM devices_attribs WHERE device_id
= ‘25’ AND attrib_type
= ‘poll_mib’ ]
Attempting to initialize OS: linux
Attempting to initialize OS: unix
OS initilized as Generic
Modules status: Global+ OS Device
Load disco module core
SNMP[/usr/bin/snmpget -v2c -c COMMUNITY -OUQn -m SNMPv2-MIB -M /opt/librenms/mibs:/opt/librenms/mibs/supermicro:/opt/librenms/mibs/dell udp:HOSTNAME:161 sysName.0 sysObjectID.0 sysDescr.0]
...0 = ge-ups
...0 = ..4.1.8.2
...0 = Linux GEDE-SNMP-UPS-Interface 2.4.20-guaranty #1 Sun Sep 6 16:04:51 CST 2009 armv5teb
Runtime for discovery module ‘core’: 0.0200 seconds with 1056 bytes
SNMP: [2/0.07s] MySQL: [8/0.00s] RRD: [0/0.00s]
Unload disco module core
Modules status: Global+ OS+ Device
Load disco module os
SNMP[/usr/bin/snmpget -v2c -c COMMUNITY -Ovq -M /opt/librenms/mibs:/opt/librenms/mibs/supermicro:/opt/librenms/mibs/dell udp:HOSTNAME:161 SNMPv2-MIB::sysDescr.0]
SNMP[/usr/bin/snmpget -v2c -c COMMUNITY -Ovqn -M /opt/librenms/mibs:/opt/librenms/mibs/supermicro:/opt/librenms/mibs/dell udp:HOSTNAME:161 SNMPv2-MIB::sysObjectID.0]
..4.1.8.2
| Linux GEDE-SNMP-UPS-Interface 2.4.20-guaranty #1 Sun Sep 6 16:04:51 CST 2009 armv5teb | .1.3.6.1.4.1.818.1.100.1.2 |
SNMP[/usr/bin/snmpget -v2c -c COMMUNITY -Oqv -m SYNOLOGY-SYSTEM-MIB -M /opt/librenms/mibs:/opt/librenms/mibs/supermicro:/opt/librenms/mibs/dell:/opt/librenms/mibs/synology udp:HOSTNAME:161 systemStatus.0]
No Such Object available on this agent at this OID
SNMP[/usr/bin/snmpget -v2c -c COMMUNITY -Oqv -M /opt/librenms/mibs:/opt/librenms/mibs/supermicro:/opt/librenms/mibs/dell udp:HOSTNAME:161 HOST-RESOURCES-MIB::hrSystemInitialLoadParameters.0]
SNMP[/usr/bin/snmpget -v2c -c COMMUNITY -Oqv -M /opt/librenms/mibs:/opt/librenms/mibs/supermicro:/opt/librenms/mibs/dell udp:HOSTNAME:161 .1.3.6.1.4.1.12148.10.2.6.0]
SNMP[/usr/bin/snmpget -v2c -c COMMUNITY -Oqv -M /opt/librenms/mibs:/opt/librenms/mibs/supermicro:/opt/librenms/mibs/dell udp:HOSTNAME:161 GANDI-MIB::rxCounter.0]
SNMP[/usr/bin/snmpbulkwalk -v2c -c COMMUNITY -Osqnv -m IEEE802dot11-MIB -M /opt/librenms/mibs:/opt/librenms/mibs/supermicro:/opt/librenms/mibs/dell udp:HOSTNAME:161 dot11manufacturerName]
SNMP[/usr/bin/snmpget -v2c -c COMMUNITY -Osqnv -m UBNT-AFLTU-MIB -M /opt/librenms/mibs:/opt/librenms/mibs/supermicro:/opt/librenms/mibs/dell:/opt/librenms/mibs/ubnt udp:HOSTNAME:161 afLTUFirmwareVersion.0]
OS: Linux (linux)
Runtime for discovery module ‘os’: 0.3150 seconds with 2056 bytes
SNMP: [8/0.31s] MySQL: [0/0.00s] RRD: [0/0.00s]
Unload disco module os
Load disco module ports
SNMP[/usr/bin/snmpbulkwalk -v2c -c COMMUNITY -OQUs -m IF-MIB -M /opt/librenms/mibs:/opt/librenms/mibs/supermicro:/opt/librenms/mibs/dell udp:HOSTNAME:161 ifDescr]
ifDescr.1 = lo
ifDescr.2 = eth0
ifDescr.3 = eth1
SNMP[/usr/bin/snmpbulkwalk -v2c -c COMMUNITY -OQUs -m IF-MIB -M /opt/librenms/mibs:/opt/librenms/mibs/supermicro:/opt/librenms/mibs/dell udp:HOSTNAME:161 ifName]
ifName = No Such Object available on this agent at this OID
SNMP[/usr/bin/snmpbulkwalk -v2c -c COMMUNITY -OQUs -m IF-MIB -M /opt/librenms/mibs:/opt/librenms/mibs/supermicro:/opt/librenms/mibs/dell udp:HOSTNAME:161 ifAlias]
ifAlias = No Such Object available on this agent at this OID
SNMP[/usr/bin/snmpbulkwalk -v2c -c COMMUNITY -OQUs -m IF-MIB -M /opt/librenms/mibs:/opt/librenms/mibs/supermicro:/opt/librenms/mibs/dell udp:HOSTNAME:161 ifType]
ifType.1 = softwareLoopback
ifType.2 = ethernetCsmacd
ifType.3 = ethernetCsmacd
Array
[1] => Array
[ifDescr] => lo
[ifType] => softwareLoopback
[2] => Array
[ifDescr] => eth0
[ifType] => ethernetCsmacd
[3] => Array
[ifDescr] => eth1
SQL[SELECT * FROM ports
WHERE device_id
= ‘25’ ORDER BY port_id]
Runtime for discovery module ‘ports’: 0.1380 seconds with 4136 bytes
SNMP: [4/0.14s] MySQL: [1/0.00s] RRD: [0/0.00s]
Unload disco module ports
Load disco module ports-stack
SQL[SELECT * FROM ports_stack
WHERE device_id
= ‘25’]
SNMP[/usr/bin/snmpbulkwalk -v2c -c COMMUNITY -OQUs -m IF-MIB -M /opt/librenms/mibs:/opt/librenms/mibs/supermicro:/opt/librenms/mibs/dell udp:HOSTNAME:161 ifStackStatus]
ifStackStatus = No Such Object available on this agent at this OID
Runtime for discovery module ‘ports-stack’: 0.0250 seconds with 1720 bytes
SNMP: [0/0.00s] MySQL: [1/0.00s] RRD: [0/0.00s]
Unload disco module ports-stack
Load disco module entity-physical
Caching OIDs: entPhysicalEntrySNMP[/usr/bin/snmpbulkwalk -v2c -c COMMUNITY -OQUs -m ENTITY-MIB:CISCO-ENTITY-VENDORTYPE-OID-MIB -M /opt/librenms/mibs:/opt/librenms/mibs/supermicro:/opt/librenms/mibs/dell udp:HOSTNAME:161 entPhysicalEntry]
entPhysicalEntry = No Such Object available on this agent at this OID
