I have a problem with fetching of disk values.
this is the result array of ./poller.php -h client.hostname.tld -m storage -d
for the main disk:
array (
'storage_id' => 4209,
'device_id' => 165,
'storage_mib' => 'hrstorage',
'storage_index' => '31',
'storage_type' => 'hrStorageFixedDisk',
'storage_descr' => '/',
'storage_size' => 63223939072,
'storage_units' => 4096,
'storage_used' => 55938183168,
'storage_free' => 7285755904,
'storage_perc' => 88,
'storage_perc_warn' => 60,
'storage_deleted' => 0,
'units' => '4096',
'used' => 55939096576,
'size' => 63223939072,
'free' => 7284842496,
while the output of df -B 1 /
shows:
Filesystem 1B-blocks Used Available Use% Mounted on
/dev/sdb1 63223939072 55940132864 4045864960 94% /
You see, the values for “size” and “used” are correctly fetched (with minor shift in “used” value due to data fetch delay), but the value for “free” is massively wrong.
The LibreNMS server and the client both run on Debian 11, and here’s the validate.php:
LibreNMS | 22.10.0-11-ga166df006 (2022-10-21T17:05:49+02:00)
DB Schema | 2022_09_03_091314_update_ports_adsl_table_with_defaults (246)
PHP | 8.1.10
Python | 3.9.2
Database | MariaDB 10.5.15-MariaDB-0+deb11u1
RRDTool | 1.7.2
SNMP | 5.9
[OK] Composer Version: 2.4.3
[OK]
[OK] MySQl and PHP time match
any idea where this comes from?
