I have two devices of same type that snmp for some reason cannot fetch system name for. I have also tried this outside of librenms with same result.
The nice thing is that you are able to assign display name and problem is solved but not quite.
Display name is not part of global search nor filter option in device search.
Is this intended behaviour? Do i have to enable something in config ?
