Since the 10th May daily update, we’re noticing an increasing amount of issues with the display of graphs.
We first noticed that after the 12th May, if we logged out and logged back in, graphs were no longer being sized to the screen width.
Prior to May 10th, that graph would have filled the screen edge to edge. My amateur digging has concluded that this relied on a session parameter called ‘widescreen’ being set, and after the May 10th update this session parameter is not being set, causing the code to default to 1075x300. I’d swear there used to be a menu option in the toolbar for toggling this.
In addition, after last night’s update, the Overall Traffic and Processors graphs on the device summary page no longer work.
This appears to be due to some change in the code for displaying graphs where the dimensions are not being set or used. The summary page attempts to use the following URL for the image:
/graph.php?to=1526552100&type=device_processor&from=1526465700&legend=no&device=55
Loading this URL results in a blank, 0 byte image. There are no errors in our logs. However if we add width and height parameters, it loads just fine.
/graph.php?to=1526552100&type=device_processor&from=1526465700&legend=no&device=55&width=800&height=300
Anyone else having these issues?
I’ve now found that when loading a page, there is an AJAX call made to /ajax/set_resolution, which fails with a 500 Internal Server Error code.
The Apache error log has the following:
production.ERROR: ErrorException: session_start(): A session had already been started - ignoring in /opt/librenms/app/Http/Controllers/AjaxController.php:17\nStack trace:\n#0 [internal function]: Illuminate\\Foundation\\Bootstrap\\HandleExceptions->handleError(8, 'session_start()...', '/opt/librenms/a...', 17, Array)\n#1 /opt/librenms/app/Http/Controllers/AjaxController.php(17): session_start()\n#2 [internal function]: App\\Http\\Controllers\\AjaxController->setResolution(Object(Illuminate\\Http\\Request))\n#3 /opt/librenms/vendor/laravel/framework/src/Illuminate/Routing/Controller.php(55): call_user_func_array(Array, Array)\n#4 /opt/librenms/vendor/laravel/framework/src/Illuminate/Routing/ControllerDispatcher.php(44): Illuminate\\Routing\\Controller->callAction('setResolution', Array)\n#5 /opt/librenms/vendor/laravel/framework/src/Illuminate/Routing/Route.php(203): Illuminate\\Routing\\ControllerDispatcher->dispatch(Object(Illuminate\\Routing\\Route), Object(App\\Http\\Controllers\\AjaxController), 'setResolution')\n#6 /opt/librenms/vendor/laravel/framework/src/Illuminate/Routing/Route.php(160): Illuminate\\Routing\\Route->runController()\n#7 /opt/librenms/vendor/laravel/framework/src/Illuminate/Routing/Router.php(572): Illuminate\\Routing\\Route->run()\n#8 /opt/librenms/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(30): Illuminate\\Routing\\Router->Illuminate\\Routing\\{closure}(Object(Illuminate\\Http\\Request))\n#9 /opt/librenms/vendor/laravel/framework/src/Illuminate/Routing/Middleware/SubstituteBindings.php(41): Illuminate\\Routing\\Pipeline->Illuminate\\Routing\\{closure}(Object(Illuminate\\Http\\Request))\n#10 /opt/librenms/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(148): Illuminate\\Routing\\Middleware\\SubstituteBindings->handle(Object(Illuminate\\Http\\Request), Object(Closure))\n#11 /opt/librenms/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(53): Illuminate\\Pipeline\\Pipeline->Illuminate\\Pipeline\\{closure}(Object(Illuminate\\Http\\Request))\n#12 /opt/librenms/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/VerifyCsrfToken.php(65): Illuminate\\Routing\\Pipeline->Illuminate\\Routing\\{closure}(Object(Illuminate\\Http\\Request))\n#13 /opt/librenms/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(148): Illuminate\\Foundation\\Http\\Middleware\\VerifyCsrfToken->handle(Object(Illuminate\\Http\\Request), Object(Closure))\n#14 /opt/librenms/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(53): Illuminate\\Pipeline\\Pipeline->Illuminate\\Pipeline\\{closure}(Object(Illuminate\\Http\\Request))\n#15 /opt/librenms/vendor/laravel/framework/src/Illuminate/Session/Middleware/AuthenticateSession.php(39): Illuminate\\Routing\\Pipeline->Illuminate\\Routing\\{closure}(Object(Illuminate\\Http\\Request))\n#16 /opt/librenms/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(148): Illuminate\\Session\\Middleware\\AuthenticateSession->handle(Object(Illuminate\\Http\\Request), Object(Closure))\n#17 /opt/librenms/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(53): Illuminate\\Pipeline\\Pipeline->Illuminate\\Pipeline\\{closure}(Object(Illuminate\\Http\\Request))\n#18 /opt/librenms/vendor/laravel/framework/src/Illuminate/View/Middleware/ShareErrorsFromSession.php(49): Illuminate\\Routing\\Pipeline->Illuminate\\Routing\\{closure}(Object(Illuminate\\Http\\Request))\n#19 /opt/librenms/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(148): Illuminate\\View\\Middleware\\ShareErrorsFromSession->handle(Object(Illuminate\\Http\\Request), Object(Closure))\n#20 /opt/librenms/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(53): Illuminate\\Pipeline\\Pipeline->Illuminate\\Pipeline\\{closure}(Object(Illuminate\\Http\\Request))\n#21 /opt/librenms/vendor/laravel/framework/src/Illuminate/Session/Middleware/StartSession.php(64): Illuminate\\Routing\\Pipeline->Illuminate\\Routing\\{closure}(Object(Illuminate\\Http\\Request))\n#22 /opt/librenms/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(148): Illuminate\\Session\\Middleware\\StartSession->handle(Object(Illuminate\\Http\\Request), Object(Closure))\n#23 /opt/librenms/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(53): Illuminate\\Pipeline\\Pipeline->Illuminate\\Pipeline\\{closure}(Object(Illuminate\\Http\\Request))\n#24 /opt/librenms/vendor/laravel/framework/src/Illuminate/Cookie/Middleware/AddQueuedCookiesToResponse.php(37): Illuminate\\Routing\\Pipeline->Illuminate\\Routing\\{closure}(Object(Illuminate\\Http\\Request))\n#25 /opt/librenms/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(148): Illuminate\\Cookie\\Middleware\\AddQueuedCookiesToResponse->handle(Object(Illuminate\\Http\\Request), Object(Closure))\n#26 /opt/librenms/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(53): Illuminate\\Pipeline\\Pipeline->Illuminate\\Pipeline\\{closure}(Object(Illuminate\\Http\\Request))\n#27 /opt/librenms/vendor/laravel/framework/src/Illuminate/Cookie/Middleware/EncryptCookies.php(59): Illuminate\\Routing\\Pipeline->Illuminate\\Routing\\{closure}(Object(Illuminate\\Http\\Request))\n#28 /opt/librenms/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(148): Illuminate\\Cookie\\Middleware\\EncryptCookies->handle(Object(Illuminate\\Http\\Request), Object(Closure))\n#29 /opt/librenms/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(53): Illuminate\\Pipeline\\Pipeline->Illuminate\\Pipeline\\{closure}(Object(Illuminate\\Http\\Request))\n#30 /opt/librenms/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(102): Illuminate\\Routing\\Pipeline->Illuminate\\Routing\\{closure}(Object(Illuminate\\Http\\Request))\n#31 /opt/librenms/vendor/laravel/framework/src/Illuminate/Routing/Router.php(574): Illuminate\\Pipeline\\Pipeline->then(Object(Closure))\n#32 /opt/librenms/vendor/laravel/framework/src/Illuminate/Routing/Router.php(533): Illuminate\\Routing\\Router->runRouteWithinStack(Object(Illuminate\\Routing\\Route), Object(Illuminate\\Http\\Request))\n#33 /opt/librenms/vendor/laravel/framework/src/Illuminate/Routing/Router.php(511): Illuminate\\Routing\\Router->dispatchToRoute(Object(Illuminate\\Http\\Request))\n#34 /opt/librenms/vendor/laravel/framework/src/Illuminate/Foundation/Http/Kernel.php(176): Illuminate\\Routing\\Router->dispatch(Object(Illuminate\\Http\\Request))\n#35 /opt/librenms/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(30): Illuminate\\Foundation\\Http\\Kernel->Illuminate\\Foundation\\Http\\{closure}(Object(Illuminate\\Http\\Request))\n#36 /opt/librenms/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/TransformsRequest.php(30): Illuminate\\Routing\\Pipeline->Illuminate\\Routing\\{closure}(Object(Illuminate\\Http\\Request))\n#37 /opt/librenms/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(148): Illuminate\\Foundation\\Http\\Middleware\\TransformsRequest->handle(Object(Illuminate\\Http\\Request), Object(Closure))\n#38 /opt/librenms/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(53): Illuminate\\Pipeline\\Pipeline->Illuminate\\Pipeline\\{closure}(Object(Illuminate\\Http\\Request))\n#39 /opt/librenms/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/TransformsRequest.php(30): Illuminate\\Routing\\Pipeline->Illuminate\\Routing\\{closure}(Object(Illuminate\\Http\\Request))\n#40 /opt/librenms/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(148): Illuminate\\Foundation\\Http\\Middleware\\TransformsRequest->handle(Object(Illuminate\\Http\\Request), Object(Closure))\n#41 /opt/librenms/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(53): Illuminate\\Pipeline\\Pipeline->Illuminate\\Pipeline\\{closure}(Object(Illuminate\\Http\\Request))\n#42 /opt/librenms/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/ValidatePostSize.php(27): Illuminate\\Routing\\Pipeline->Illuminate\\Routing\\{closure}(Object(Illuminate\\Http\\Request))\n#43 /opt/librenms/vendor/laravel/framework/src/Illumin
Commenting out session_start() from this file fixes both graph display issues.
