Hi
How do I make a world map with all my devices on it, and display it to the world without having to log in?
I just need a read only world status map with my devices on it. (plus the red/green for down/up status).
Hi
It is best to use an additional login and just check the remember me option.
Yea, that’s not gonna cut it.
Maybe i’ll just copy pasta the current world map code, and make a plugin that is accessible from world.
You can add the login to the url, but I don’t suggest that.
