Displaying Temps in Fahrenheit
I am moving our lab temperature monitoring to LibreNMS. We would like it to report room temperatures in Fahrenheit. Can we change the PDU sensors to report F instead of C with the UI?
If not, I can modify the discovery scripts so that my APC PDU’s return Fahrenheit values instead of Celsius. But I still would need to change the display for the APC temp values from ‘C’ to ‘F’ to avoid user confusion.
Is there a way to get Libre to convert to ‘F’ within the UI or as a fall back to displaying ‘F’ instead of ‘C’ for my APC PDUtemps?
I have the same requirement.
Hi @Alireza_Fallah_Jeddi
This is not supported currently. Anyone is very welcome to submit a Pull Request with this feature.
