I have a distributed poller setup
1 Server with DB
1 Server with rrd, rrdcache, and memcache
5 different pollers
While trying to get everything going, when I run the validate to determine if my setup is correct it’s complaining memcache isn’t working.
./validate.php -g distributedpoller
Component |
Version |
LibreNMS |
1.51-14-g554e22d |
DB Schema |
2019_02_10_220000_add_dates_to_fdb (390) |
PHP |
7.2.16 |
MySQL |
5.7.14-8-log |
RRDTool |
1.7.1 |
SNMP |
NET-SNMP 5.7.2 |
[OK] Composer Version: 1.8.5
Checking distributedpoller: FAIL
[FAIL] We could not get memcached stats, it is possible that we cannot connect to your memcached server, please check
I have the following in the config.php
cat config.php | grep memcache
$config[‘memcached’][‘enable’] = true;
$config[‘memcached’][‘host’] = “X.X.X.X”;
$config[‘memcached’][‘port’] = 11211;
$config[‘distributed_poller_memcached_host’] = ‘X.X.X.X’;
$config[‘distributed_poller_memcached_port’] = ‘11211’;
I installed the php memcache extension: sudo yum install php72w-pecl-memcached.x86_64. I installed this on all the pollers.
How do I go about troubleshooting this? It also does not appear that memcache is listening on port 11211.
Did you start your memcached server?
What is the command to start it? Below - which was my guess, did not work.
sudo systemctl start memcached
Failed to start memcached.service: Unit not found.
Did you install memcached on one server?
That part was slightly unclear to me. Please let me know what are the correct steps.
One a single server I installed:
- libevent
- libevent-devel
- python-memcached
- php72w-pecl-memcached
On all the other I installed:
- python-memcached
I tried a sudo yum install memcached, but I get an error “No package memcached available.
Error: Nothing to do”.
Thanksl
So you haven’t installed memcached, only language plugins…
It is probably called just memcache
OK I think I have some of the problems fixed.
- libevent
- libevent-devel
- python-memcached
- memcached
On all the other pollers I installed:
- python-memcached
memcached is now showing it is running:
● memcached.service - Memcached
Loaded: loaded (/usr/lib/systemd/system/memcached.service; enabled; vendor preset: disabled)
Active: active (running) since Fri 2019-05-10 15:52:39 CDT; 7min ago
Main PID: 184743 (memcached)
CGroup: /system.slice/memcached.service
└─184743 /usr/bin/memcached -u memcached -p 11211 -m 64 -c 1024
And now I am seeing the right results:
[ ./validate.php -g distributedpoller
Component |
Version |
LibreNMS |
1.51-14-g554e22d |
DB Schema |
PHP |
7.2.16 |
MySQL |
5.7.14-8-log |
RRDTool |
1.7.1 |
SNMP |
NET-SNMP 5.7.2 |
Checking distributedpoller: OK
Final 2 questions:
Do I need to modify any of the package installs listed above? should the language plugins be removed from the pollers?
Also do I need remove the first 3 lines listed from my config.php and just leave the ones referencing the distributed poller?
Thanks again for all the help on this one.
The first three aren’t actually settings in LibreNMS, you can remove them.
