Can anyone clear up some documentation confusion please? Looking at:
It states “Pick one of the following setups, do not use all of them at the same time.”, so we’ve configured two servers, one of which is our DB/Redis/Web server, the other is just our Poller. We selected redis because documentation states “preferred”
However, the log files on the poller give the following warning:
tail /opt/librenms/logs/poller_wrapper.log
2022-02-09 18:25:05,391 :: WARNING :: Could not connect to memcached, disabling distributed service checks.
./validate.php also fails because there is no memcached:
[FAIL] We could not get memcached stats, it is possible that we cannot connect to your memcached server, please check
So, is the “Pick one” wrong or misleading? Even if we use the preferred Redis, we still need memcached as well?
Thanks, but that doesn’t answer my question. That video is more of a tutorial. I’ve already followed various tutorials. None of which explain the issue as to why are the logs and ./validate.php are complaining about memcached, if memcached is not configured anywhere. Per the documentation, and that tutorial, all references to memcached have been commented out.
Thanks for the quick reply. I thought about that…and I was going to get to that eventually. However, would that explain why ./validate.php is failing?
LibreNMS | 22.1.0-54-gb9e55bc46
DB Schema | 2021_12_02_113537_ports_stp_designated_cost_change_to_int (234)
PHP | 7.4.19
Python | 3.6.8
MySQL | 10.6.5-MariaDB-log
RRDTool | 1.7.0
SNMP | 5.8
[OK] Composer Version: 2.2.6
[INFO] Detected Python Wrapper
I don’t have memcached configured anywhere (that I can find), so why is that failing?
Because you are using the wrapper scripts which depend on memcached so validate is checking for that. Switch to the dispatcher and the issue will go away.
Dispatcher setup straight forward and easy, but validate is sill failing. I can see redis MONITOR scrolling by with both IPs (web server and poller) and /opt/librenms/logs/librenms.log shows the normal:
And syslog shows new:
Feb 10 12:53:21 librenms-02 librenms-service.py[2045997]: Discovery_1-5(INFO):Completed discovery run for 299 (1) in 19.99s
Feb 10 12:53:21 librenms-02 librenms-service.py[2045997]: Discovery_1-5(INFO):Discovering device 320
Feb 10 12:53:22 librenms-02 librenms-service.py[2045997]: Discovery_1-6(INFO):Completed discovery run for 295 (1) in 20.32s
Feb 10 12:53:22 librenms-02 librenms-service.py[2045997]: Discovery_1-6(INFO):Discovering device 318
Feb 10 12:53:22 librenms-02 librenms-service.py[2045997]: Discovery_1-15(INFO):Completed discovery run for 276 (1) in 21.38s
…etc.
But still getting the same complaint about memcached.
LibreNMS | 22.1.0-55-ga49ee59c0
PHP | 7.4.19
Python | 3.6.8
RRDTool | 1.7.0
SNMP | 5.8
I was running validate too quickly. I thought that validate would pass per node…but you have to update ALL nodes at the same time, and then validate passes for everything. Interesting, but good to know.
Thank you both for all the quick help, everything is good to go!
