We have 4 servers
1 - Primary plus web GUI
2.- DB server
3- rrd
4 - Distributed poller
All configuration done, no errors when ran ./validate.php
While trying to add device getting snmp authetication error, I am able to do snmpwalk for the device from distributed poller. Kindly any one suggest why getting snmp connection error. Thank you
When you add a device the WebUI performs the connectivity checks; If that server has no access to the devices then you can simply tick Force-Add to bypass that initial check and the Pollers will pick it up from there.
